Hi @WayneWWW , thanks for getting back on this. Do you expect Jetson TX2 AP wifi clients to be able to negotiate to 40/80 MHz bandwidth without the suggested changes ? I see that AP is able to advertise 80Mhz capabilities on air.
Below is the wifi scan dump on client when associated with Jetson TX2 AP:
pi@raspberrypi : ~ $ sudo iw wlan0 scan
BSS 00:04:4b:f8:66:06(on wlan0) – associated
last seen: 4185.558s [boottime]
TSF: 0 usec (0d, 00:00:00)
freq: 5240
beacon interval: 100 TUs
capability: ESS Privacy SpectrumMgmt (0x0111)
signal: -31.00 dBm
last seen: 0 ms ago
SSID: XXXX-YYYY
Supported rates: 6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0
Country: XT Environment: Indoor/Outdoor
Channels [36 - 36] @ 23 dBm
Channels [40 - 40] @ 23 dBm
Channels [44 - 44] @ 23 dBm
Channels [48 - 48] @ 23 dBm
Channels [52 - 52] @ 23 dBm
Channels [56 - 56] @ 23 dBm
Channels [60 - 60] @ 23 dBm
Channels [64 - 64] @ 23 dBm
Power constraint: 0 dB
TPC report: TX power: 12 dBm
RSN: * Version: 1
- Group cipher: CCMP
- Pairwise ciphers: CCMP
- Authentication suites: PSK
- Capabilities: 16-PTKSA-RC 1-GTKSA-RC (0x000c)
HT capabilities:
Capabilities: 0x6f
RX LDPC
HT20/HT40
SM Power Save disabled
RX HT20 SGI
RX HT40 SGI
No RX STBC
Max AMSDU length: 3839 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 4 usec (0x05)
HT RX MCS rate indexes supported: 0-15
HT TX MCS rate indexes are undefined
HT operation:
- primary channel: 48
- secondary channel offset: below
- STA channel width: any
- RIFS: 1
- HT protection: no
- non-GF present: 1
- OBSS non-GF present: 0
- dual beacon: 0
- dual CTS protection: 0
- STBC beacon: 0
- L-SIG TXOP Prot: 0
- PCO active: 0
- PCO phase: 0
Extended capabilities:
- Extended Channel Switching
- Interworking
- QoS Map
- Operating Mode Notification
- Max Number Of MSDUs In A-MSDU is unlimited
VHT capabilities:
VHT Capabilities (0x0f815832):
Max MPDU length: 11454
Supported Channel Width: neither 160 nor 80+80
RX LDPC
short GI (80 MHz)
SU Beamformer
SU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
VHT operation:
*** channel width: 1 (80 MHz)**
*** center freq segment 1: 42**
- center freq segment 2: 0
- VHT basic MCS set: 0x0000
WMM: * Parameter version 1
- u-APSD
- BE: CW 15-1023, AIFSN 3
- BK: CW 15-1023, AIFSN 7
- VI: CW 7-15, AIFSN 2, TXOP 3008 usec
- VO: CW 3-7, AIFSN 2, TXOP 1504 usec
