We purchased one Jetson TX2 developer kit last year and two TX2 core modules recently. Everything works fine except the 5G wifi. We cannot find any 5G signal on all TX2 even with antenna provided by developer kit but we can easily find same 5G wifi with our laptop.However 2.4G works mostly ok, occasionally unstable.
As far as I know, 5G is originally supported by TX2. I am wondering is there any way that we can enable or use 5G wifi?
$ iwconfig
lo no wireless extensions.
wlp1s0 IEEE 802.11 ESSID:"BJ_5G"
Mode:Managed Frequency:5.765 GHz Access Point: 8C:3B:AD:22:04:06
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
However on TX2, it shows:
$ iwlist chan
usb0 no frequency information
lo no frequency information
dummy0 no frequency information
wlan0 no frequency information
l4tbr0 no frequency information
usb1 no frequency information
tunl0 no frequency information
eth0 no frequency information
$ iwconfig
usb0 no wireless extensions
dummy0 no wireless extensions
wlan0 no wireless extensions
l4tbr0 no wireless extensions
usb1 no wireless extensions
tunl0 no wireless extensions
eth0 no wireless extensions
$ rfkill list
0: bluedroid_pm: Bluetooth
Soft blocked: yes
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: brcmfmac-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
My apology in advance because I really don’t know what is your usecase.
I also don’t know why you got this conclusion that it is a supported band problem in China.
Tegra has passed the wifi certification in China, so it must have some 5G channels supported. The problem here looks like your AP is running a channel that tegra not supports.
Could you configure your AP into other channel?
If not, please share what is your usecase. What channel is your target?
I check with my router vendor Netgear and the following forum. I change the nation(or country) to the US and set 5G signal channel to 36. And then my Jetson TX2 can access to 5G.
