Hi I’m trying to build scripts on the TX1 so the device starts as an access point, provides a GUI to list available Wifi networks, user selects a network and it leaves AP mode and connects to Wifi. I’m running into a few problems if someone can shed some light on possible solutions.
While in AP mode (op_mode 2) if I run $ sudo iwlist wlan0 scan it says the network adapter does not support scanning. This does work with op_mode 0. How can I scan while in AP mode?
I wrote a bash script following these instructions to create an AP: https://devtalk.nvidia.com/default/topic/910608/jetson-tx1/setting-up-wifi-access-point-on-tx1/post/4902927/#4902927 but I’m having trouble swapping back to Wifi. I know the settings are being cleared. What’s the best way to restart networking after you’ve made changes to /etc/network/interfaces?
I haven’t experimented with the wifi, but depending on what software is present, this might do the job:
sudo service networking restart
# (see also "service networking status")
DmitriK
February 24, 2017, 12:28am
3
I also cannot scan in AP mode:
iw dev wlan0 scan
command failed: Invalid argument (-22)
iwlist wlan0 scan
wlan0 Interface doesn’t support scanning : Invalid argument
kernel log shows these errors:
Feb 23 23:57:48 orbitty kernel: [85260.642719] CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
Feb 23 23:57:48 orbitty kernel: [85260.642788] CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
Is Scanning supported in AP mode? Is it a bug? Any special kernel config options for bc wifi driver?
Is automatic channel selection supported? Like setting channel=0 in hostapd config?
here is my iw list:
# iw list
Wiphy phy0
Band 1:
Capabilities: 0x1020
HT20
Static SM Power Save
RX HT20 SGI
No RX STBC
Max AMSDU length: 3839 bytes
DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 16 usec (0x07)
HT RX MCS rate indexes supported: 0-7
HT TX MCS rate indexes are undefined
Frequencies:
* 2412 MHz [1] (20.0 dBm)
* 2417 MHz [2] (20.0 dBm)
* 2422 MHz [3] (20.0 dBm)
* 2427 MHz [4] (20.0 dBm)
* 2432 MHz [5] (20.0 dBm)
* 2437 MHz [6] (20.0 dBm)
* 2442 MHz [7] (20.0 dBm)
* 2447 MHz [8] (20.0 dBm)
* 2452 MHz [9] (20.0 dBm)
* 2457 MHz [10] (20.0 dBm)
* 2462 MHz [11] (20.0 dBm)
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Band 2:
HT20
RX HT20 SGI
No RX STBC
DSSS/CCK HT40
Frequencies:
* 5180 MHz [36] (20.0 dBm)
* 5200 MHz [40] (20.0 dBm)
* 5220 MHz [44] (20.0 dBm)
* 5240 MHz [48] (20.0 dBm)
* 5260 MHz [52] (20.0 dBm) (passive scanning, no IBSS, radar detection)
* 5280 MHz [56] (20.0 dBm) (passive scanning, no IBSS, radar detection)
* 5300 MHz [60] (20.0 dBm) (passive scanning, no IBSS, radar detection)
* 5320 MHz [64] (20.0 dBm) (passive scanning, no IBSS, radar detection)
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
max # scan SSIDs: 10
max scan IEs length: 2048 bytes
Coverage class: 0 (up to 0m)
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP (00-0f-ac:4)
* CMAC (00-0f-ac:6)
Available Antennas: TX 0 RX 0
Supported interface modes:
* IBSS
* managed
* AP
* P2P-client
* P2P-GO
* Unknown mode (10)
software interface modes (can always be added):
valid interface combinations:
* #{ AP } <= 1, #{ managed } <= 2, #{ P2P-client, P2P-GO } <= 2, #{ Unknown mode (10) } <= 1, #{ IBSS } <= 1,
total <= 4, #channels <= 2
Supported commands:
* new_interface
* set_interface
* new_key
* new_beacon
* set_bss
* join_ibss
* set_pmksa
* del_pmksa
* flush_pmksa
* remain_on_channel
* action
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* Unknown command (82)
* Unknown command (81)
* Unknown command (75)
* Unknown command (89)
* connect
* disconnect
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* Unknown mode (10): 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0xd0
* managed: 0x40 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* Unknown mode (10): 0x40 0xd0
WoWLAN support:
* wake up on anything (device continues operating normally)
Re: If channel is not specified then a channel will be picked up by WiFi FW.
Randomly?
No, it would pick a fixed one.
