Unable to switch to 5GHz in Intel 8265 chip
Hi, I am qualifying Intel AC 8265 WiFi for our product. I am not able switch to 5GHz in this one. But I am able to switch to 2.4GHz. When i print iw list it shows No IR in the 5GHz band. How to resolve this?
Wiphy phy0
        max # scan SSIDs: 20
        max scan IEs length: 464 bytes
        max # sched scan SSIDs: 20
        max # match sets: 11
        max # scan plans: 2
        max scan plan interval: 65535
        max scan plan iterations: 254
        Retry short limit: 7
        Retry long limit: 4
        Coverage class: 0 (up to 0m)
        Device supports RSN-IBSS.
        Device supports AP-side u-APSD.
        Device supports T-DLS.
        Supported Ciphers:
                * WEP40 (00-0f-ac:1)
                * WEP104 (00-0f-ac:5)
                * TKIP (00-0f-ac:2)
                * CCMP-128 (00-0f-ac:4)
                * CMAC (00-0f-ac:6)
        Available Antennas: TX 0 RX 0
        Supported interface modes:
                 * IBSS
                 * managed
                 * AP
                 * AP/VLAN
                 * monitor
                 * P2P-client
                 * P2P-GO
                 * P2P-device
        Band 1:
                Bitrates (non-HT):
                        * 1.0 Mbps
                        * 2.0 Mbps (short preamble supported)
                        * 5.5 Mbps (short preamble supported)
                        * 11.0 Mbps (short preamble supported)
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 2412 MHz [1] (22.0 dBm)
                        * 2417 MHz [2] (22.0 dBm)
                        * 2422 MHz [3] (22.0 dBm)
                        * 2427 MHz [4] (22.0 dBm)
                        * 2432 MHz [5] (22.0 dBm)
                        * 2437 MHz [6] (22.0 dBm)
                        * 2442 MHz [7] (22.0 dBm)
                        * 2447 MHz [8] (22.0 dBm)
                        * 2452 MHz [9] (22.0 dBm)
                        * 2457 MHz [10] (22.0 dBm)
                        * 2462 MHz [11] (22.0 dBm)
                        * 2467 MHz [12] (disabled)
                        * 2472 MHz [13] (disabled)
        Band 2:
                Bitrates (non-HT):
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 5180 MHz [36] (22.0 dBm) (no IR)
                        * 5200 MHz [40] (22.0 dBm) (no IR)
                        * 5220 MHz [44] (22.0 dBm) (no IR)
                        * 5240 MHz [48] (22.0 dBm) (no IR)
                        * 5260 MHz [52] (22.0 dBm) (no IR, radar detection)
                        * 5280 MHz [56] (22.0 dBm) (no IR, radar detection)
                        * 5300 MHz [60] (22.0 dBm) (no IR, radar detection)
                        * 5320 MHz [64] (22.0 dBm) (no IR, radar detection)
                        * 5340 MHz [68] (disabled)
                        * 5360 MHz [72] (disabled)
                        * 5380 MHz [76] (disabled)
                        * 5400 MHz [80] (disabled)
                        * 5420 MHz [84] (disabled)
                        * 5440 MHz [88] (disabled)
                        * 5460 MHz [92] (disabled)
                        * 5480 MHz [96] (disabled)
                        * 5500 MHz [100] (22.0 dBm) (no IR, radar detection)
                        * 5520 MHz [104] (22.0 dBm) (no IR, radar detection)
                        * 5540 MHz [108] (22.0 dBm) (no IR, radar detection)
                        * 5560 MHz [112] (22.0 dBm) (no IR, radar detection)
                        * 5580 MHz [116] (22.0 dBm) (no IR, radar detection)
                        * 5600 MHz [120] (22.0 dBm) (no IR, radar detection)
                        * 5620 MHz [124] (22.0 dBm) (no IR, radar detection)
                        * 5640 MHz [128] (22.0 dBm) (no IR, radar detection)
                        * 5660 MHz [132] (22.0 dBm) (no IR, radar detection)
                        * 5680 MHz [136] (22.0 dBm) (no IR, radar detection)
                        * 5700 MHz [140] (22.0 dBm) (no IR, radar detection)
                        * 5720 MHz [144] (22.0 dBm) (no IR, radar detection)
                        * 5745 MHz [149] (22.0 dBm) (no IR)
                        * 5765 MHz [153] (22.0 dBm) (no IR)
                        * 5785 MHz [157] (22.0 dBm) (no IR)
                        * 5805 MHz [161] (22.0 dBm) (no IR)
                        * 5825 MHz [165] (22.0 dBm) (no IR)
        Supported commands:
                 * new_interface
                 * set_interface
                 * new_key
                 * start_ap
                 * new_station
                 * set_bss
                 * authenticate
                 * associate
                 * deauthenticate
                 * disassociate
                 * join_ibss
                 * remain_on_channel
                 * set_tx_bitrate_mask
                 * frame
                 * frame_wait_cancel
                 * set_wiphy_netns
                 * set_channel
                 * set_wds_peer
                 * tdls_mgmt
                 * tdls_oper
                 * start_sched_scan
                 * probe_client
                 * set_noack_map
                 * register_beacons
                 * start_p2p_device
                 * set_mcast_rate
                 * channel_switch
                 * set_qos_map
                 * add_tx_ts
                 * connect
                 * disconnect
        Supported TX frame types:
                 * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
        Supported RX frame types:
                 * IBSS: 0x40 0xb0 0xc0 0xd0
                 * managed: 0x40 0xd0
                 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * mesh point: 0xb0 0xc0 0xd0
                 * P2P-client: 0x40 0xd0
                 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * P2P-device: 0x40 0xd0
        WoWLAN support:
                 * wake up on disconnect
                 * wake up on magic packet
                 * wake up on pattern match, up to 20 patterns of 16-128 bytes,
                   maximum packet offset 0 bytes
                 * can do GTK rekeying
                 * wake up on GTK rekey failure
                 * wake up on EAP identity request
                 * wake up on 4-way handshake
                 * wake up on rfkill release
                 * wake up on network detection, up to 11 match sets
                 * wake up on TCP connection
        software interface modes (can always be added):
                 * AP/VLAN
                 * monitor
        valid interface combinations:
                 * #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1,
                   total <= 3, #channels <= 2
        HT Capability overrides:
                 * MCS: ff ff ff ff ff ff ff ff ff ff
                 * maximum A-MSDU length
                 * supported channel width
                 * short GI for 40 MHz
                 * max A-MPDU length exponent
                 * min MPDU start spacing
        Device supports TX status socket option.
        Device supports HT-IBSS.
        Device supports SAE with AUTHENTICATE command
        Device supports low priority scan.
        Device supports scan flush.
        Device supports per-vif TX power setting
        P2P GO supports CT window setting
        P2P GO supports opportunistic powersave setting
        Driver supports full state transitions for AP/GO clients
        Driver supports a userspace MPM
        Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
        Device adds DS IE to probe requests
        Device adds WFA TPC Report IE to probe requests
        Device can update TPC Report IE
        Device supports static SMPS
        Device supports dynamic SMPS
        Device supports WMM-AC admission (TSPECs)
        Device supports configuring vdev MAC-addr on create.
        Device supports TDLS channel switching
I am getting this message
Jan 28 16:12:48  hostapd[6945]: wlan1: IEEE 802.11 Configured channel (36) not found from the channel list of current mode (2) IEEE 802.11a
Jan 28 16:12:48 hostapd[6945]: wlan1: IEEE 802.11 Hardware does not support configured channel
I think this is not an issue that we can directly resolve. Maybe asking Intel would be a better option.
The wifi card may have it own country code and where you enable the wifi channel may affect the result too.
If you take this error as search keyword, you would see some comments like changing the country code/regulatory. We also don’t have such tool for this since we are not wifi card vendor.
