Hi all,
I’ve been fighting with trying to create a 5ghz AP/STA and I came across an interesting discovery. I’m wondering if any of you have experienced this. The card in the Nano shows that 4 channels in the 5ghz range can radiate, but the Xavier does not.
One thing I noticed in the iw reg list output below, is that iw recognizes the region as US on the Nano, but not on the Xavier. Does anyone know if this has something to do with the deployment of the OS against the particular platforms? I’ve attempted to set the regions on the Xavier, but they don’t change. This may have something to do with the wifi card permissions.
My two setups are:
- Jetson Nano w/ dev board.
- Jetson Xavier AGX w/ dev board.
Both units have a intel 8265NGW mini-pciE card installed with antennas attached.
iw list output for both cards (I’m only clipping the important bits):
Nano:
sudo lspci
01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
Subsystem: Intel Corporation Dual Band Wireless-AC 8265
Flags: bus master, fast devsel, latency 0, IRQ 408
Memory at 13000000 (64-bit, non-prefetchable)
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number c8-09-a8-ff-ff-ff-0f-5a
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [154] L1 PM Substates
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
iw list
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* P2P-client
* P2P-GO
* P2P-device
Frequencies:
* 5180 MHz [36] (22.0 dBm)
* 5200 MHz [40] (22.0 dBm)
* 5220 MHz [44] (22.0 dBm)
* 5240 MHz [48] (22.0 dBm)
iwconfig wlan0
wlan0 IEEE 802.11 Mode:Master Tx-Power=22 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
sudo iwconfig wlan0 mode master
Error for wireless request "Set Mode" (8B06) :
SET failed on device wlan0 ; Invalid argument.
iw reg get
global
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, NO-IR
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, NO-IR
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, NO-IR
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, NO-IR
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, NO-IR
(5735 - 5835 @ 80), (N/A, 20), (N/A), NO-IR
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
country US: DFS-UNSET
(2402 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5250 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5250 - 5330 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5490 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5735 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5815 - 5835 @ 20), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
Xavier:
sudo lspci
0003:01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
Flags: bus master, fast devsel, latency 0, IRQ 1075
Memory at 12b0000000 (64-bit, non-prefetchable)
Capabilities: [140] Device Serial Number 98-af-65-ff-ff-46-12-66
iw list
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* P2P-client
* P2P-GO
* P2P-device
Frequencies:
* 5180 MHz [36] (22.0 dBm) (no IR)
* 5200 MHz [40] (22.0 dBm) (no IR)
* 5220 MHz [44] (22.0 dBm) (no IR)
* 5240 MHz [48] (22.0 dBm) (no IR)
iwconfig wlan0
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Frequency:2.437 GHz Access Point: Not-Associated
Tx-Power=22 dBm
Power Management:on
SET failed on device wlan0 ; Operation not permitted.
iw reg get
global
(2402 - 2472 @ 40), (6, 20), (N/A)
(2457 - 2482 @ 20), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (6, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN
(5170 - 5250 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5735 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5815 - 5835 @ 20), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, PASSIVE-SCAN
