Hello
I am working on realtime streaming application for my client. I am using Jetson (AGX and Nano), NvVideoEncoder C++ API and I am encoding h.265. Recently I started using Slice Level Encode to retrieve slices of the frame being encoded ASAP, even before the encoding process for the remainder of frame ends.
My code also makes use of encoder output metadata. I’ve noticed that while that metadata is fine when Slice Level Encode is disabled, it is unreliable, at times almost zeroed out when Slice Level Encode is on. In order to demonstrate the problem I used the 01_video_encode sample from Jetson multimedia API samples:
/usr/src/jetson_multimedia_api/samples/01_video_encode/video_encode ../videos/nv12_sample.yuv 1920 1080 H265 experiment.h265 --sp -slt 2 -slen 1000 --report-metadata
This produces the following output:
Frame 0: isKeyFrame=1 AvgQP=29 MinQP=27 MaxQP=30 EncodedBits=468472
Frame 1: isKeyFrame=0 AvgQP=30 MinQP=29 MaxQP=32 EncodedBits=99704
Frame 2: isKeyFrame=0 AvgQP=31 MinQP=30 MaxQP=32 EncodedBits=67448
Frame 3: isKeyFrame=0 AvgQP=31 MinQP=30 MaxQP=32 EncodedBits=63672
Frame 4: isKeyFrame=0 AvgQP=32 MinQP=32 MaxQP=32 EncodedBits=57456
Frame 5: isKeyFrame=0 AvgQP=31 MinQP=31 MaxQP=32 EncodedBits=72800
Frame 6: isKeyFrame=0 AvgQP=30 MinQP=30 MaxQP=32 EncodedBits=164912
Frame 7: isKeyFrame=0 AvgQP=29 MinQP=29 MaxQP=31 EncodedBits=209096
Frame 8: isKeyFrame=0 AvgQP=29 MinQP=29 MaxQP=30 EncodedBits=204808
Frame 9: isKeyFrame=0 AvgQP=29 MinQP=29 MaxQP=29 EncodedBits=230704
Frame 10: isKeyFrame=0 AvgQP=30 MinQP=30 MaxQP=30 EncodedBits=189872
Frame 11: isKeyFrame=0 AvgQP=31 MinQP=31 MaxQP=31 EncodedBits=178832
Frame 12: isKeyFrame=0 AvgQP=31 MinQP=31 MaxQP=31 EncodedBits=193624
Frame 13: isKeyFrame=0 AvgQP=32 MinQP=32 MaxQP=32 EncodedBits=121288
Frame 14: isKeyFrame=0 AvgQP=32 MinQP=32 MaxQP=32 EncodedBits=179456
Frame 15: isKeyFrame=0 AvgQP=32 MinQP=32 MaxQP=32 EncodedBits=163544
Frame 16: isKeyFrame=0 AvgQP=32 MinQP=32 MaxQP=32 EncodedBits=154256
Frame 17: isKeyFrame=0 AvgQP=32 MinQP=32 MaxQP=32 EncodedBits=161848
Frame 18: isKeyFrame=0 AvgQP=33 MinQP=33 MaxQP=33 EncodedBits=120120
Frame 19: isKeyFrame=0 AvgQP=33 MinQP=33 MaxQP=33 EncodedBits=129904
Frame 20: isKeyFrame=0 AvgQP=33 MinQP=33 MaxQP=33 EncodedBits=131976
and so on. Nothing to see here, everything is fine. But once I enable Slice Level Encode, things change. Command in use is:
/usr/src/jetson_multimedia_api/samples/01_video_encode/video_encode ../videos/nv12_sample.yuv 1920 1080 H265 experiment.h265 --sp -slt 2 -slen 1000 --report-metadata --sle
Here I can see very different picture:
Frame 0: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 1: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 2: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 3: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 4: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 5: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 6: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 7: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 8: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 9: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 10: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 11: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 12: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 13: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 14: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 15: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 16: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 17: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 18: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 19: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 20: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
This is clear nonsense. First frame IS a keyframe, it’s QPs aren’t all equal to zero (and this is not lossless encoding), EncodedBits can’t be zero either (now that would be amazing compression ;-) ) and so on…let’s wait for awhile, and some reasonable information will actually appear:
Frame 58: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 59: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 60: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 61: isKeyFrame=1 AvgQP=29 MinQP=27 MaxQP=30 EncodedBits=468472
Frame 62: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 63: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 64: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
and then after a looong time output is more like
Frame 1450: isKeyFrame=0 AvgQP=30 MinQP=30 MaxQP=30 EncodedBits=104352
Frame 1451: isKeyFrame=0 AvgQP=30 MinQP=30 MaxQP=30 EncodedBits=100784
Frame 1452: isKeyFrame=0 AvgQP=33 MinQP=33 MaxQP=33 EncodedBits=113240
Frame 1453: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 1454: isKeyFrame=0 AvgQP=32 MinQP=32 MaxQP=32 EncodedBits=89728
Frame 1455: isKeyFrame=0 AvgQP=29 MinQP=29 MaxQP=30 EncodedBits=138264
Frame 1456: isKeyFrame=0 AvgQP=31 MinQP=31 MaxQP=31 EncodedBits=103352
Frame 1457: isKeyFrame=0 AvgQP=30 MinQP=30 MaxQP=30 EncodedBits=96384
Frame 1458: isKeyFrame=0 AvgQP=0 MinQP=0 MaxQP=0 EncodedBits=0
Frame 1459: isKeyFrame=0 AvgQP=29 MinQP=29 MaxQP=30 EncodedBits=135808
Frame 1460: isKeyFrame=0 AvgQP=30 MinQP=30 MaxQP=30 EncodedBits=109136
Frame 1461: isKeyFrame=0 AvgQP=30 MinQP=28 MaxQP=31 EncodedBits=99464
Frame 1462: isKeyFrame=0 AvgQP=30 MinQP=30 MaxQP=31 EncodedBits=586184
So ALMOST all entries make sense, but not all of them. I think it is a bug.
Regards
Michal
