So I’m currently using L4T 34.1 and booting from a nvme drive, usually everything works just fine, but occasionally it looks like the default boot option nvme0n1p1 gets moved to the bottom of the boot list and it will try to boot from the network by default. The only way I’ve found to permanently fix this is to boot the device up and delete the other boot options from the boot menu, but I’d like to be able to have those boot options be removed at the time that I flash the Jetson. Is there a config file I can modify before flashing to remove any unwanted boot options?
35.1 has been released, please try with the new one first.
