Jetson Xavier + docker + ffmpeg
I’m trying to build a docker image on my jetson Xavier NX using:
FROM nvcr.io/nvidia/l4t-pytorch:r32.4.4-pth1.6-py3
and of course the image runs fine, my problems araises when I try to compile this GitHub - jocover/jetson-ffmpeg: ffmpeg support on jetson nano inside the Dockerfile. The thing is that cmake cannot find jetson_mutimedia_api folder. Is there a way to install it when using a docker imager? I need to install jocover’s solution since there’s no ffmpeg encoding support at this time.
Please add the directory to
/etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv
And restart the docker.
Thanks a lot! that solved my problem
