Hi!
I am planning to design a custom board based on jetson XAVIER NX. I am a little confused about the programming of the MCU Chip.
After reading the forum, I had understood that this chip will be programmed through the C2 interface for which I had left a header with the connections of C2CK, C2D, and Ground.
I also got the firmware file from the forum. The problem is that what will be the programming interface of this firmware? Do I need any other hardware/programmer/debugger or what else do I need to program the chip?
Regards,
Ather
For devkit, it has been flashed. For custom design, the circuit design should follow reference and customer should get the flashing instructions from Silicon Labs.
Ok
I will contact silicon labs for the programming of the IC.
