Jetson xavier nx deepstream Yolov5
How can I solve it?
Could you share the source you are using with us first?
Is it a public sample?
I used deepstream 6.0, jetpack 4.6
In the figure on the top, there is a serialized engine being used.
Does the engine is generated in the same environment?
More, if you are using Xavier, it’s recommended to upgrade to JetPack 5.1+Deepstream 6.2.
Hi. The engine is produced by deepstream’s tool.
duplicate with Segmentation fault
add information here
My platform is Jetson Xavier nx.
Jetpack4.6
Deep stream 6.0
When I used usb camera to launch yolov5 by deepstream-yolo6.0 , I meet this question
Segmentation fault
  1. you might to use our official yolov5 sample: deepstream_tao_apps/configs/yolov5_tao at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
  2. there are some steps to do DeepStream-Yolo/YOLOv5.md at master · marcoslucianops/DeepStream-Yolo · GitHub, if still failed, could you share more logs? please do “export GST_DEBUG=6” first to modify Gstreamer’s log level, then run again, you can redirect the logs to a file.
