I’m trying to run yolov3 with deepstream5 following the steps in this link: How to detect objects with Nvidia Deepstream 4.0 and YOLO in 5 minutes - Deep Learning and AI related blog
desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo$ deepstream-app -c deepstream_app_config_yoloV3.txt
Warn: ‘threshold’ parameter has been deprecated. Use ‘pre-cluster-threshold’ instead.
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
dlopen error: libvisionworks.so: cannot open shared object file: No such file or directory
gstnvtracker: Failed to initilaize low level lib.
** ERROR: main:651: Failed to set pipeline to PAUSED
Quitting
App run failed
• Jetson
• DeepStream5.0
• JetPack Version 4.4
• TensorRT 7.1
• cuda 10.2
