DS : Yolo and Other Sample Apps not running when tracker is enabled in Config Files
• Hardware Platform (Jetson / GPU) - Jetson (Nano 4 Gb)
• DeepStream Version 6.0.0
• JetPack Version (valid for Jetson only) 4.6.1
• TensorRT Version 8.2.1.8
CUDA 10.2 and Cudnn 8.2.1.32
• Issue Type ( questions or may be bugs)
CLI Command
deepstream-app -c ./deepstream_app_config_yoloV3_tiny.txt
OUTPUT
(gst-plugin-scanner:12591): GStreamer-WARNING **: 16:19:50.412: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:12591): GStreamer-WARNING **: 16:19:50.420: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:12591): GStreamer-WARNING **: 16:19:50.709: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-plugin-scanner:12591): GStreamer-WARNING **: 16:19:50.844: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
Unknown or legacy key specified 'is-classifier' for group [property]
Warn: 'threshold' parameter has been deprecated. Use 'pre-cluster-threshold' instead.
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
 dlopen error: /opt/nvidia/vpi1/lib64/libnvvpi.so.1: undefined symbol: NvMediaLDCUpdateTNR2Params
gstnvtracker: Failed to initilaize low level lib.
** ERROR: <main:658>: Failed to set pipeline to PAUSED
Quitting
App run failed
Extra Information
  1. i have libnvvpi.so.1 >> PATH is : /opt/nvidia/vpi1/lib64/libnvvpi.so.1
  2. i have libnvds_nvmultiobjecttracker.so >> PATH is : /opt/nvidia/deepstream/deepstream-
  3. All permissions of opt directory are read and write
  4. When i use sudo deepstream-app -c <file_name> GStreamer-WARNING donot come but error still occurs
  5. When i do enable = 0 for tracker in CONFIG files… Yolo and other apps works perfect
Please refer to Frequently Asked Questions — DeepStream 6.1.1 Release documentation
And please make sure your DS 6.0 GA or DS 6.0.1 have been installed correctly.
