Thank you. That got me started but when I try and flash the dev kit, it is asking for the login and password on the kit. Since I don’t know this since I can’t login at all, how do I reset or create a new user on the kit? I tried the Ubuntu ‘hold down the shift key during boot’ but it doesn’t recognize it.
Flash is normally just to install the operating system. It is after flash completes and the system self-reboots that it asks for a name/pass for the purpose of installing other software, e.g., CUDA. The problem is that the first boot requires you to run the first boot account setup, otherwise there won’t be a login name or password. Does it give you an opportunity during boot to set this up if you run either from a local monitor/keyboard, or via serial console?
