Flashed Jetson Xavier NX completed but no change on the device
I have flashed a Jetson Xavier NX with SDK manager (Host is Ubuntu 20.04) with jetpack 5.1.2. It displayed a success message, but when booting the jetson, it remained unchanged (all files and configurations still there). Is there a way to resolve this? I want to completely reset the image of the Jetson.
Any advice would be appreciated.
Flashing log?
What storage device is it booting from?
When you say flashing log, do you mean the Debug Log from SDK manager?
I am using a host machine running linux ubuntu 20.04 which is connected to the jetson via usb.
YES.
I mean what storage device is Jetson using.
The device has a 128SSD
What do you get with df -h?
I still need the flashing log.
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_Xavier_NX_modules_2023-12-19_16-34-13.zip (112.7 KB)
Is it a DevKit or a custom carrier board?
The issue is that you only re-flashed the eMMC on the module, but you still booted from NVMe, which is not updated at all.
If it’s a DevKit, make sure you select the right storage device in SDK Manager.
If it’s a custom carrier board, please contact the board vendor.
