Hello, I am trying to flash a Xaiver NX via NVIDIA SDK.
I encounter an error saying as like an attached file around 10% of the process.
Jetson Nano can be flashed using the same host PC and USB cable.
SDKM_logs_JetPack_4.5.1_(rev.1)_Linux_for_Jetson_Xavier_NX_2021-10-02_17-20-16.zip (158.9 KB)
I can check there is ‘Bus 003 Device 087: ID 0955:7e19 NVidia Corp.’ when I use a ‘Bus 003 Device 087: ID 0955:7e19 NVidia Corp.’ command before flashing.
Thank you
No, I am using just normal Ubuntu 18.04, not VM.
Yes, I have one more NX board although I need to detach it from robot.
kayccc
October 21, 2021, 1:16am
5
Hi kimbring2 ,
Have you managed to get device flash successfully?
Any result can be shared?
Thank you for checking.
I am waiting until the Jetson NX device will be available for sale at Amazon. It looks not a good idea not to detach the working one from the robot.
I can figure out the problem of not working one after I obtain a new device.
