HI
The module’s i2c not work, when I use i2cdetect, the dmesg
session.log (248.2 KB)
shows log below, we use offical binary from manager software, so what is the issue?
HI
What’s the command for i2cdetect?
What’s the version? Any slave device connect?
Hi
Thanks for the reply
There is a battery i2c device connect to the i2c bus (tegra-i2c c240000.i2c)
but I can not detect the device by using [i2cdetect -y -r 1]
after the command, I use dmesg and found [tegra-i2c c240000.i2c: pio timed out addr: 0x3 tlen:12 rlen:4]
the official sdk binary is 32.6.1 in [ Jetson Linux Archive | NVIDIA Developer]
Did you probe to check if the batter chip have ack for the bus boardcast?
Fixed issue, it is a hardware resource config error. thanks
