Jetson Xavier NX Flash Failure "Task 50 failed (err: 0x7979061c
I come across a recent issue when trying to reflash an Xavier NX module. I am using the command line command and Jetson Linux R32.7.1 and the sample rootfs from the archives. I am flashing from a host Ubuntu 20.04 where the UART logs are seen below:
[0085.285] E> Task 50 failed (err: 0x7979061c)
[0085.289] E> Top caller module: ALIASCHECKER, error module: ALIASCHECKER, reason: 0x1c, aux_info: 6
[0085.298] I> MB1(1.5.1.9-t194-41334769-73a9b7ef) BIT boot status dump :
0000000000011111111110000111111111111110011000111110000000000000000000000000000000000000000000000000
[0085.328] I> Reset to recovery mode
Is this module bricked and in need of a RMA or is there something being setup/performed incorrectly
The full UART and flash script logs are here:
serial.log (5.7 KB)
log.txt (46.4 KB)
Please also try 32.7.4 and 35.5.
If it throws the same error, then it’s likely this modules is bricked and needs RMA.
No luck with either 32.7.4 or 35.5. Attached the logs for completeness with guidance to RMA.
Tegra35.5.0_host.log (38.8 KB)
Tegra35.5.0_serial.log (5.2 KB)
Tegra32.7.4_host.log (46.6 KB)
Tegra32.7.4_serial.log (4.0 KB)
Then please follow the guidance for RMA:
