Hi, after a lot of pain I managed to procure the Jetson xavier nx board for my college project through my college.
I had high expectations of the same, I flashed an SD card with the Jetpack 4.5.x through Balena Etcher after formatting it with the help of SD card Formatter.
I expected to see an Nvidia logo on my screen, but apparently there is no signal received by the monitor connected via HDMI.
I made use of another SD card, used a different version of Jetpack, went through youtube tutorials and documentation. Iterated the whole process 6 times, but screen receives no output.
The fan does spin now and then. There is a solid green light on the board which indicates good power input.
Tested with 2 sd cards, 2 hdmi cables and 2 monitors, but all in vain. I am simply unable see anything on the monitor.
I looked into few tutorials of ssh into board after connecting it to the laptop via micro USB. I managed to successfully ssh, and do the setup process, however I failed connecting the board to wifi device. It always returned passphrase error even though the password was correct, I skipped this step and managed to use screen terminal and enter the jetson board.
So 2 issues I have are:
1)No display on the monitor, not even the starting nvidia logo.
2)Failure of internet connection during the initial setup.
Tell me if I have missed some point. I have begun feeling it could be a hardware defect. I don’t have a second piece to confirm the same. Any quick response would help.
