Hi
Intel I211 LAN EEPROMAccessTool(V 0.7.9) Flash in UBUNTU18.04 for Tegra (ARM64, r32.4.2, Jetson Xavier NX)
Eepromaccesstool 0.7.9 Dump error message “Check command open to write error” appears, the dumped OTP file is empty 0, the previous OTP burning back will also cause an error.
To update the firmware, which apps to update? Or is it set in the environment?
thanks.
Hi tom.lin,
Sorry that we don’t know anything about this tool. Could you check what is the requirement for this tool?
It looks like everything goes error in this app.
Hi Wayne
This problem does not occur when we use the x86 platform. Is there any suggestion?
thanks.
Sorry, as I said in previous comment: I have 0 knowledge about this tool. This tool is from Intel so you better asking them for detail about this tool first.
