I am using jetson xavier nx production module with custom board similar to xavier devkit
I am trying to flash the jetson xavier nx but the flashing process getting terminated.
I have flashed the board number of times before as well but this time i am facing this issue. I am using the sdk manager tool, host machine with ubuntu 20.04, jetpack : 5.1.2
I have confirmed the the usb is connected to the host and jetson in between the process
I tried with different host machine with ubuntu 20.04 as well the issue continues
It seems that the board value being read from your board’s EEPROM doesn’t match the Xavier NX module. If you are sure that you have the correct module, it could be that the EEPROM is corrupted. I have seen posts on here about manually reading and correcting the EEPROM values, but I haven’t tried it myself.
Here are the values for the different boards:
Building the massfuse blob with OFFLINE method requires:
Same as ONLINE method. See ``Building the Massfuse Blob with ONLINE
method'' above.
To generate the massfuse blob with OFFLINE method:
- Enter the command `cd Linux_for_Tegra`.
- No actual jetson device attachment is necessary.
- Just add ``BOARDID=<boardid> BOARDSKU=<sku> FAB=<fab>'' in front of
``./nvmassfusegen.sh'' as in ONLINE method:
BOARDID=<boardid> BOARDSKU=<sku> FAB=<fab> \
FUSELEVEL=fuselevel_production ./nvmassfusegen.sh \
<odm fuse options> <device_name>
Where actual values are:
BOARDID BOARDSKU FAB BOARDREV
jetson-agx-xavier-industrial 2888 0008 600 A.0
jetson-xavier-nx-devkit-tx2-nx 3636 0001 100 B.0
jetson-xavier-nx-devkit-emmc 3668 0001 100 N/A
jetson-nano-devkit-emmc 3448 0002 200 N/A
jetson-agx-xavier-devkit (16GB) 2888 0001 400 H.0
jetson-agx-xavier-devkit (32GB) 2888 0004 400 K.0
jetson-tx2-devkit 3310 1000 B02 N/A
jetson-tx2-devkit-tx2i 3489 0000 300 A.0
jetson-tx2-devkit-4gb 3489 0888 300 F.0
jetson-tx1-devkit 2180 0000 400 N/A
If someone face the same issue ever.
Goto the downloaded sdk manager folder Linux_for_Tegra .
use this command to flash sudo SKIP_EEPROM_CHECK=1 BOARDID=3668 BOARDSKU=0001 ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
jetson-xavier-nx-devkit-emmc → for 16 GB production module
jetson-xavier-nx-devkit → for developer kit
The above command will skip reading the board information from the eeprom instread we will provide the board info as arguments.
Thanks to @miguel.taylor for providing the board information
