Hi everyone,
some thing wrong when i type :
sudo ./flash.sh -r p3449-0000+p3668-0001-qspi-emmc mmcblk0p1
with a carrier board (with jetson nx module (16g emmc)) we did.
ub@ub:~/data/aiboxv1.2/Linux_for_Tegra$ sudo ./flash.sh -r p3449-0000+p3668-0001-qspi-emmc mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 4.3
# Target Board Information:
# Name: p3449-0000+p3668-0001-qspi-emmc, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
copying soft_fuses(/home/data/aiboxv1.2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/data/aiboxv1.2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0030 ] Generating RCM messages
[ 0.0048 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0064 ] Header already present for /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0140 ]
[ 0.0154 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0169 ] Assuming zero filled SBK key
[ 0.0172 ]
[ 0.0189 ] tegrasign_v2 --key None --file /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0205 ] Assuming zero filled SBK key
[ 0.0216 ]
[ 0.0232 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0303 ]
[ 0.0321 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0339 ]
[ 0.0357 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0369 ] RCM 0 is saved as rcm_0.rcm
[ 0.0413 ] RCM 1 is saved as rcm_1.rcm
[ 0.0413 ] RCM 2 is saved as rcm_2.rcm
[ 0.0413 ] List of rcm files are saved in rcm_list.xml
[ 0.0413 ]
[ 0.0414 ] Signing RCM messages
[ 0.0431 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0447 ] Assuming zero filled SBK key
[ 0.0458 ]
[ 0.0458 ] Copying signature to RCM mesages
[ 0.0474 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0492 ]
[ 0.0493 ] Boot Rom communication
[ 0.0511 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0521 ] RCM version 0X190001
[ 0.0535 ] Boot Rom communication completed
[ 1.0686 ]
[ 2.0720 ] tegrarcm_v2 --isapplet
[ 2.0739 ] Applet version 01.00.0000
[ 2.0920 ]
[ 2.0942 ] tegrarcm_v2 --ismb2
[ 2.1275 ]
[ 2.1297 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.1319 ]
[ 2.1340 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.1359 ] adding BCH for nvtboot_applet_t194.bin
[ 2.1400 ]
[ 2.1419 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.1429 ] Assuming zero filled SBK key
[ 2.1433 ]
[ 2.1527 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.1559 ]
[ 2.1568 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.1584 ] Applet version 01.00.0000
[ 2.1758 ] Sending mb2
[ 2.1760 ] [................................................] 100%
[ 2.1887 ]
[ 2.1908 ] tegrarcm_v2 --boot recovery
[ 2.1925 ] Applet version 01.00.0000
[ 2.2152 ]
[ 3.2182 ] tegrarcm_v2 --isapplet
[ 3.2364 ]
[ 3.2383 ] tegrarcm_v2 --ismb2
[ 3.2400 ] MB2 Applet version 01.00.0000
[ 3.2723 ]
[ 3.2744 ] tegrarcm_v2 --ismb2
[ 3.2763 ] MB2 Applet version 01.00.0000
[ 3.3122 ]
[ 3.3134 ] Retrieving EEPROM data
[ 3.3135 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/cvm.bin
[ 3.3150 ] MB2 Applet version 01.00.0000
[ 3.3503 ] 0000000036260706: E> I2C: Timeout while polling for transfer complete. Last value 0x00000002.
[ 3.4148 ]
[ 3.4148 ]
[ 3.4170 ] tegradevflash_v2 --oem platformdetails eeprom cvm /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/cvm.bin
[ 3.4188 ] CPU Bootloader is not running on device.
[ 3.4218 ]
Error: Return value 4
Command tegradevflash_v2 --oem platformdetails eeprom cvm /home/data/aiboxv1.2/Linux_for_Tegra/bootloader/cvm.bin
Reading board information failed.
