Jetson Xavier-NX EMMC 16GB flashing issue
I’m using Jetson NANO carrier board for Jetson XAVIER-NX. Jetson Xavier-NX module comes with EMMC option only (without SDcard slot). We are not able to flash through the SDK-Manager.
We have done the following steps:
  1. Place a jumper across the Force Recovery Mode pins (9 and 10) on the button header
    [J14].
  2. Connect your host computer to the developer kit’s USB Micro-B connector.
  3. Connect the power supply to the power jack [J16]. The developer kit automatically
    powers on in Force Recovery Mode.
  4. Remove the jumper from the Force Recovery Mode pins
Kindly help on this.
Below are the terminal output:
15:40:45 INFO : Flash Jetson Xavier NX (Devkit) : [ 19.3348 ] [… ] 018% [ 19.3348 ] [… ] 036% [ 19.3348 ] [… ] 055% [ 19.3348 ] [… ] 073% [ 19.3348 ] [… ] 092% [ 19.3348 ] […] 100%
15:40:45 INFO : Flash Jetson Xavier NX (Devkit) : [ 20.1617 ]
15:40:45 INFO : Flash Jetson Xavier NX (Devkit) : [ 20.1631 ] tegrarcm_v2 --boot recovery
15:40:45 INFO : Flash Jetson Xavier NX (Devkit) : [ 20.1645 ] Applet version 01.00.0000
15:40:46 INFO : Flash Jetson Xavier NX (Devkit) : [ 20.1735 ]
15:40:46 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.1761 ] tegrarcm_v2 --isapplet
15:40:46 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.1819 ]
15:40:46 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.1837 ] tegrarcm_v2 --ismb2
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.1956 ]
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.2637 ] tegradevflash_v2 --iscpubl
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.2654 ] Bootloader version 01.00.0000
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.2897 ] Bootloader version 01.00.0000
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.2935 ]
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.2935 ] Retrieving storage infomation
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.2949 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.2959 ] Applet is not running on device. Continue with Bootloader
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3052 ]
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3065 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3073 ] Bootloader version 01.00.0000
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3119 ] Saved platform info in storage_info.bin
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3161 ]
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3162 ] Flashing the device
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3174 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3188 ]
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3200 ] tegradevflash_v2 --pt flash.xml.bin --create
15:40:47 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3208 ] Bootloader version 01.00.0000
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ 21.3256 ] Erasing spi: 0 … [Done]
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ 123.3369 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ 123.3376 ] […] 100%
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ 123.5604 ] Erasing sdcard: 0 … 0000000074740311: E> NV3P_SERVER: Failed to open instance 0 of device 6.
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ 123.5650 ]
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ 123.5650 ] [Failed]
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ 123.5651 ]
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : Error: Return value 17
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : Command tegradevflash_v2 --pt flash.xml.bin --create
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : Failed flashing t186ref.
15:42:29 ERROR : Flash Jetson Xavier NX (Devkit) : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_NX_DEVKIT_WITH_OS_IMAGE_COMP.sh; [error]: exit status 1
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ Component Install Finished with Error ]
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ 9.34 GB used. Disk Avail: 38.74 GB ]
15:42:29 INFO : Flash Jetson Xavier NX (Devkit) : [ NV_L4T_FLASH_XAVIER_NX_DEVKIT_WITH_OS_IMAGE_COMP Install took 13m12s ]
15:42:29 ERROR : Flash Jetson Xavier NX (Devkit) : [error]: Run commands failed at step Install: command /tmp/tmp_NV_L4T_FLASH_XAVIER_NX_DEVKIT_WITH_OS_IMAGE_COMP.sh finished with error
15:42:29 ERROR : Flash Jetson Xavier NX (Devkit) : command terminated with error
15:42:29 ERROR : Flash Jetson Xavier NX (Devkit) : Install ‘Flash Jetson Xavier NX (Devkit)’ failure, command < using adapter to install NV_L4T_FLASH_XAVIER_NX_DEVKIT_WITH_OS_IMAGE_COMP@JETSON_XAVIER_NX_DEVKIT to /home/vkchcp0013/nvidia/nvidia_sdk/JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX_DEVKIT > terminated with error.
15:42:30 INFO : All done!
Do you mean your NX module does not have a sdcard slot but only emmc?
yes.It has only emmc
There are two problems here
  1. If you are using emmc based NX module, then you have to choose the non-devkit option in sdkmanager.
  2. I am not very sure if production NX module is able to run on Nano devkit. Please try (1) first.
