Hello everyone nVIDIA
Is data written in the EEPROM for RTL 8153 in the shipping state of Jonston_TX 1? (Vendor ID, MAC address, etc.)
- When it is written
Please tell me about the contents of the data
Is it possible to rewrite?
- When not written
Please tell me how to write
that’s all, Best regard.
I don’t know what is actually written where, but you can find more about MAC and MAC manipulation within the u-boot command line environment. You can attach a serial console, hit a key very early on to interrupt boot, and then type “help” on the command line to see options (such as printing environment, and this would give some MAC information). See:
[url]http://elinux.org/Jetson/TX1_Serial_Console[/url]
Hello linuxdev.
Your answer is not what I expected.
The MAC address should be saved inside the EEPROM connected to the SPI interface terminal of RTL 8153 (Ethernet).
This means that it is a component mounted on the board of the Jetson_TX1 module.
When using Jeston_TX1 as an OEM product, it should be the customer’s vendor ID and MAC address.
· Please tell me how to process these data in the manufacturing process of Jetson_TX1. (Do you write data? What is the content of the data?)
· Can you rewrite with Jetson_TX1’s serial console?
best regards.
Hi BlueYatagarasu,
Please follow the NVIDIA JETSON TX1 MODULE EEPROM LAYOUT in
http://developer.nvidia.com/embedded/dlc/l4t-documentation-24-2
