JP6.0DP, Orin can not wake up by mouse or keyboard
Hi ,
My AGX ORIN dev kit of JP6.0DP has this suspend/resume issue. My test steps is:
1. power on the ORIN dev kit.
2. click "suspend" under the power menu by a usb mouse, then the system suspend and the display is off.
3. click mouse again, or type something by keybord, and system dose not wake up.
Please give some help.
How did you tell the device is wake up or not? Are you using the monitor to check?
or serial console?
Hi WayneWWW,
I used both monitor and serial console.
After I clicked the ‘suspend’ item of the desktop, the monitor turned to black, and the serial console reported:
 ▒▒DCE RM Suspend rmStatus:0x0
▒▒[   41.955575] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[   41.955583] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[   41.955588] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[   41.955594] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
▒▒▒▒clk_mach_suspend_early
clk_mach_suspend_early done
suspended vdd_core @ 950000uV
▒▒spe entering sc7
▒▒clk_mach_suspend
clk_mach_suspend done
fmon_suspend done
t234_adc_suspend done
WAKE_MASK[31:0]  = 0x21000000
WAKE_MASK[63:32] = 0x0
WAKE_MASK[95:64] = 0x100200
TIER0[31:0]      = 0x0
TIER0[63:32]     = 0x0
TIER0[95:64]     = 0x0
TIER1[31:0]      = 0x0
TIER1[63:32]     = 0x0
TIER1[95:64]     = 0x0
TIER2[31:0]      = 0x21000000
TIER2[63:32]     = 0x0
TIER2[95:64]     = 0x200
Then I clicked the mouse key or type something by the keyboard, and the serial console did not print anything, and the monitor kept a black screen.
We can reproduce this issue. Will have further check.
Hi WayneWWW,
Any word on this issue?
It seems we are encountering the same issue (can’t wake from keyboard or mouse) on Jetson Orin NX 16gb(s) with JP 6.0.
Our testing of RTC works but USB type-C cable hotplug and USB remote don’t seem to work.
This issue would be fixed in next release.
Thanks. Any idea of the timing? Last we saw was JP6.1 was targeting Q3 2024.
Please wait for our announcement.
The JetPack 6.1 GA SW has been released at Sep/28. Thanks
