JPEG parameter struct mismatch: library thinks size is 728, caller expects 720
I’ve settled a CSI-camera and try to use nvgstcapture-1.0 to open it. But the error shows
Here is libjpeg version show by apt list | grep libjpeg for your information:
libjpeg-dev/focal,now 8c-2ubuntu8 arm64 [installed]
libjpeg-progs/focal 1:9d-1 arm64
libjpeg-tools/focal 0.0~git20190821.87636f3b26b4-1.1 arm64
libjpeg-turbo-progs/focal-updates,focal-security 2.0.3-0ubuntu1.20.04.3 arm64
libjpeg-turbo-test/focal-updates,focal-security 2.0.3-0ubuntu1.20.04.3 arm64
libjpeg-turbo8-dbg/focal-updates,focal-security 2.0.3-0ubuntu1.20.04.3 arm64
libjpeg-turbo8-dev/focal-updates,focal-security,now 2.0.3-0ubuntu1.20.04.3 arm64 [installed,automatic]
libjpeg-turbo8/focal-updates,focal-security,now 2.0.3-0ubuntu1.20.04.3 arm64 [installed,automatic]
libjpeg62-dev/focal 1:6b2-3 arm64
libjpeg62/focal 1:6b2-3 arm64
libjpeg8-dbg/focal 8c-2ubuntu8 arm64
libjpeg8-dev/focal,now 8c-2ubuntu8 arm64 [installed,automatic]
libjpeg8/focal,now 8c-2ubuntu8 arm64 [installed,automatic]
libjpeg9-dev/focal 1:9d-1 arm64
libjpeg9/focal 1:9d-1 arm64
Do you know How to fix this?
Here is the environment:
Environment:
Jetpack: 5.1.3
python: 3.8
Gstreamer: 1.16.3
OpenCV:4.5.4
System: Ubuntu 20.04
What’s the camera output size?
It’s 1280*720.
Please try gst-launch-1.0 command to check if the issue is specific to nvgstcapture-1.0:
$ gst-launch-1.0 nvarguscamerasrc ! fakesink
The sigsegv happens in this case:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Caught SIGSEGV
Spinning.  Please run 'gdb gst-launch-1.0 4298' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
We don’t expect the error on default Jetpack release. Please clean gstreamer cache and see if you can successfully run the command.
How to clean gstreamer cache? I’m a new user and not familiar with gstreamer.
Please try
$ rm ~/.cache/gstreamer-1.0/registry.aarch64.bin
Clearing cache doesn’t help. After clearing the cache and run gst-launch-1.0 nvarguscamerasrc ! fakesink
SIGSEGV still repeats:
(gst-plugin-scanner:11054): GStreamer-WARNING **: 11:21:18.496: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so’: /lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
(gst-plugin-scanner:11054): GStreamer-WARNING **: 11:21:18.566: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: /lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
Caught SIGSEGV
Spinning. Please run ‘gdb gst-launch-1.0 11053’ to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
Please re-flash the system to 5.1.3 through SDKManager and try again. It would be great to have a clean system and check if the issue still occurs.
Is is possible to re-flash system directly via ubuntu in jetson instead of SDK manager in a host computer? It’s because now I don’t have available host linux system.
No, you need to have a host PC with Ubuntu.
