• Hardware Platform: Jetson Xavier NX
**• DeepStream Version: 6.2 **
**• JetPack Version: 5.1, 5.1.2 **
• TensorRT Version
• Issue Type: bug
I have a DS 6.0 C++ app that works fine on one Jetson Xavier NX device.
Today I tried to make and run it on another Jetson Xavier NX with newer Jetpack and DS 6.2 installed.
It runs but dumps core upon saving a cropped image on disk with the following message:
JPEG parameter struct mismatch: library thinks size is 720, caller expects 728
I looked up the forum and noticed it’s a well known issue.
I installed Jetpack 5.1 from a SD card and followed these instructions to install dependencies and Deepstream 6.2. I also had to do the follwong to be able to make it:
sudo apt-get install libgstreamer1.0-dev libjson-glib-dev libgstrtspserver-1.0-dev libjpeg-dev
but it still gives me the same error.
I was able to make and run deepstream-image-meta-test sample.
So my question is - what else can I try to make it work as it works on older Jetpack/DS6.0?
