JPEG parameter struct mismatch: library thinks size is 720, caller expects 728 on Xavier
This is related to this: JPEG parameter struct mismatch: library thinks size is 584, caller expects 728 for python3 in Jetson
But I am having same issue in both 5.0.2 and 5.1.1.
I believe this has to do with libjpeg library. The error pops up when I send a jpeg using nvds_obj_enc_process in my application. Any advice ?.
• DeepStream Version
• TensorRT Version
**• Hardware Platform: Xavier 32 GB
**• DeepStream Version: 6.2
**• JetPack Version 5.1.1
Sorry I did not include earlier as I linked the related post and that hardware was the same.
Can you run the deepstream-image-meta-test sample in your board?
