0
I am trying to run the darknet_video.py script for YOLO from here
in Jetson (nano and xavier NX). The code runs fine in one nano but not in another nano and NX. The script is run using the following command in Ubuntu 18.04 (Jetpack)
python3 darknet_video.py --input test.mp4 --out_filename out1.txt --weights yolov3-tiny.weights --ext_output --config_file yolov3-tiny.cfg --data_file coco.data --thresh 0.2
Receivng the follwing error in a nano and NX but it runs fine in another nano:
JPEG parameter struct mismatch: library thinks size is 584, caller expects 728
pure virtual method called
terminate called without an active exception
Aborted (core dumped)
