• Hardware Platform (Jetson / GPU) Jetson Orin NX 16G • DeepStream Version 6.3 • JetPack Version (valid for Jetson only) 5.1.3 • TensorRT Version 8.5.2.2
I run deepstream-image-meta-test ,but get error: JPEG parameter struct mismatch: library thinks size is 728, caller expects 720. How to solve this problem?
Are you using a Devkit without any library updated? The error message indicates the mismatch of libraries, normally using library from different Jetpack.
