• Hardware Platform (Jetson / GPU): Jetson Xavier AGX
• DeepStream Version: 6.2
• JetPack Version (valid for Jetson only) : 5.1.1
• TensorRT Version: 8.5.2.2
• Issue Type( questions, new requirements, bugs): bugs
I want to test saving images function by using nvds_obj_enc_process in deepstream-transfer-learning-app sample. This function still work in previous version, specify version 6.0 ( I have not tested on version 6.1 yet). Below is my config used for test:
- config_infer_primary_ds_transfer_learning.txt
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../../../../samples/models/Primary_Detector/resnet10.caffemodel
proto-file=../../../../../samples/models/Primary_Detector/resnet10.prototxt
model-engine-file=../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
labelfile-path=../../../../../samples/models/Primary_Detector/labels.txt
int8-calib-file=../../../../../samples/models/Primary_Detector/cal_trt.bin
batch-size=30
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
force-implicit-batch-dim=1
#parse-bbox-func-name=NvDsInferParseCustomResnet
#custom-lib-path=/path/to/libnvdsparsebbox.so
## 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=1
#scaling-filter=0
#scaling-compute-hw=0
[class-attrs-all]
pre-cluster-threshold=0.2
group-threshold=1
## Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
## Per class configuration
#[class-attrs-2]
#threshold=0.6
#eps=0.5
#group-threshold=3
#roi-top-offset=20
#roi-bottom-offset=10
#detected-min-w=40
#detected-min-h=40
#detected-max-w=400
#detected-max-h=800
- ds_transfer_learning_app_example.txt
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../../../../samples/streams/sample_1080p_h264.mp4
num-sources=4
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_ds_transfer_learning.txt
[tracker]
enable=1
# For NvDCF and NvDeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_IOU.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvSORT.yml
ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[tests]
file-loop=0
[img-save]
enable=1
gpu-id=0
output-folder-path=./output
save-img-cropped-obj=0
save-img-full-frame=1
frame-to-skip-rules-path=capture_time_rules.csv
second-to-skip-interval=600
min-confidence=0.9
max-confidence=1.0
min-box-width=5
min-box-height=5
- The result I got after using `GST_DEBUG=3’:
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
0:00:02.294906608 18014 0xaaaaba91d8d0 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-transfer-learning-app/configs/../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.349474353 18014 0xaaaaba91d8d0 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-transfer-learning-app/configs/../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
0:00:02.417272344 18014 0xaaaaba91d8d0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-transfer-learning-app/configs/config_infer_primary_ds_transfer_learning.txt sucessfully
0:00:02.419508608 18014 0xaaaaba91d8d0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:02.420627988 18014 0xaaaaba91d8d0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:02.422403782 18014 0xaaaaba91d8d0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:02.423052612 18014 0xaaaaba91d8d0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:02.425431442 18014 0xaaaaba91d8d0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:02.426221847 18014 0xaaaaba91d8d0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:02.428318296 18014 0xaaaaba91d8d0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:00:02.429368713 18014 0xaaaaba91d8d0 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:239>: Pipeline ready
0:00:02.441430520 18014 0xfffe9c0300c0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux1> failed to find fragment defaults for stream 1
0:00:02.441486490 18014 0xfffe9c0309e0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:00:02.441839627 18014 0xfffeb000ef60 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux3> failed to find fragment defaults for stream 1
0:00:02.441906958 18014 0xfffe9c0309e0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
0:00:02.441917038 18014 0xfffe9c0300c0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux1> failed to find fragment defaults for stream 2
0:00:02.442064757 18014 0xfffec00130c0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux2> failed to find fragment defaults for stream 1
0:00:02.442243645 18014 0xfffeb000ef60 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux3> failed to find fragment defaults for stream 2
0:00:02.442320161 18014 0xfffec00130c0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux2> failed to find fragment defaults for stream 2
Opening in BLOCKING MODE
0:00:02.692045784 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.692207712 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe80023770 Failed to determine interlace mode
0:00:02.692319941 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe80023770 Failed to determine interlace mode
0:00:02.692396936 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe80023770 Failed to determine interlace mode
0:00:02.692453835 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe80023770 Failed to determine interlace mode
0:00:02.693557246 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:<nvv4l2decoder2:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.693716358 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe8801c020 Failed to determine interlace mode
0:00:02.693838027 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe8801c020 Failed to determine interlace mode
0:00:02.693905582 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe8801c020 Failed to determine interlace mode
0:00:02.694005811 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe8801c020 Failed to determine interlace mode
NvMMLiteOpen : Block : BlockType = 261
0:00:02.704788007 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:<nvv4l2decoder1:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.706025312 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7c01c880 Failed to determine interlace mode
0:00:02.706917225 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7c01c880 Failed to determine interlace mode
0:00:02.707916152 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7c01c880 Failed to determine interlace mode
0:00:02.708033821 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7c01c880 Failed to determine interlace mode
0:00:02.708642361 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:<nvv4l2decoder3:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.708869028 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7401f0e0 Failed to determine interlace mode
0:00:02.709028875 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7401f0e0 Failed to determine interlace mode
0:00:02.709111311 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7401f0e0 Failed to determine interlace mode
0:00:02.709169746 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7401f0e0 Failed to determine interlace mode
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:02.925699782 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:<nvv4l2decoder2:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.925838636 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe8801c020 Failed to determine interlace mode
0:00:02.925976019 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe8801c020 Failed to determine interlace mode
0:00:02.926100569 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe8801c020 Failed to determine interlace mode
0:00:02.926186045 18014 0xfffec402d640 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe8801c020 Failed to determine interlace mode
0:00:02.926338436 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:<nvv4l2decoder1:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.926324099 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.926549005 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe80023770 Failed to determine interlace mode
0:00:02.926477066 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7c01c880 Failed to determine interlace mode
0:00:02.926720149 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe80023770 Failed to determine interlace mode
0:00:02.926760375 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7c01c880 Failed to determine interlace mode
0:00:02.926809337 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe80023770 Failed to determine interlace mode
0:00:02.926910526 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:4512:gst_v4l2_object_probe_caps:<nvv4l2decoder3:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:02.926938079 18014 0xfffe8c007800 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe80023770 Failed to determine interlace mode
0:00:02.926952768 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7c01c880 Failed to determine interlace mode
0:00:02.927150537 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7401f0e0 Failed to determine interlace mode
0:00:02.927233005 18014 0xfffe84008920 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7c01c880 Failed to determine interlace mode
0:00:02.927389364 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7401f0e0 Failed to determine interlace mode
0:00:02.927560060 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7401f0e0 Failed to determine interlace mode
0:00:02.927689154 18014 0xfffe8c0082a0 WARN v4l2 gstv4l2object.c:2398:gst_v4l2_object_add_interlace_mode:0xfffe7401f0e0 Failed to determine interlace mode
** INFO: <bus_callback:225>: Pipeline running
0:00:02.941483554 18014 0xfffe84008920 WARN v4l2videodec gstv4l2videodec.c:1880:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder1> Duration invalid, not setting latency
0:00:02.942806367 18014 0xfffe8c007800 WARN v4l2videodec gstv4l2videodec.c:1880:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:02.942960550 18014 0xfffe8c0082a0 WARN v4l2videodec gstv4l2videodec.c:1880:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder3> Duration invalid, not setting latency
0:00:02.943246451 18014 0xfffec402d640 WARN v4l2videodec gstv4l2videodec.c:1880:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder2> Duration invalid, not setting latency
0:00:02.982402058 18014 0xfffe84008920 WARN v4l2bufferpool gstv4l2bufferpool.c:1114:gst_v4l2_buffer_pool_start:<nvv4l2decoder1:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:02.984212830 18014 0xfffe8c007800 WARN v4l2bufferpool gstv4l2bufferpool.c:1114:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:02.984779640 18014 0xfffe8c0082a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1114:gst_v4l2_buffer_pool_start:<nvv4l2decoder3:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:02.985124648 18014 0xfffec402d640 WARN v4l2bufferpool gstv4l2bufferpool.c:1114:gst_v4l2_buffer_pool_start:<nvv4l2decoder2:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:03.006357536 18014 0xfffe940095e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1565:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:03.007760545 18014 0xfffe88020b60 WARN v4l2bufferpool gstv4l2bufferpool.c:1565:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder1:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:03.009251206 18014 0xfffe8007a0c0 WARN v4l2bufferpool gstv4l2bufferpool.c:1565:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder2:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:03.010989559 18014 0xfffe7c024ea0 WARN v4l2bufferpool gstv4l2bufferpool.c:1565:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder3:pool:src> Driver should never set v4l2_buffer.field to ANY
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 33.66 (29.63) 33.66 (29.63) 33.66 (29.63) 33.66 (29.63)
JPEG parameter struct mismatch: library thinks size is 720, caller expects 728
The configure is kept as default expect I change the EglSink to FakeSink. So I think the configure is not the reason for problem. I also tried to re-install libjpeg-dev package from some reference on forum but It’s also not work for my case.
Thank you for reading and I hope to hear from you ASAP.
