I’m using buildroot to generate a filesystem and kernel for an Orin-based project and the kernel build fails with a number of linker errors (see below). I’m using the bootlin 2020.08-1 toolchain that’s given in the release notes. Googling hasn’t turned up anything helpful. Anyone have any ideas?
/home/output/ips/host/bin/aarch64-linux-ld: Unexpected GOT/PLT entries detected!
/home/output/ips/host/bin/aarch64-linux-ld: Unexpected run-time procedure linkages detected!
/home/output/ips/host/bin/aarch64-linux-ld: drivers/misc/eventlib/eventlib_flt.o: in function `sync_clear_bit':
/home/output/ips/build/linux-5.10.120/nvidia/drivers/misc/eventlib/eventlib_flt.h:170: undefined reference to `__aarch64_ldclr4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: drivers/misc/eventlib/eventlib_flt.o: in function `sync_set_bit':
/home/output/ips/build/linux-5.10.120/nvidia/drivers/misc/eventlib/eventlib_flt.h:165: undefined reference to `__aarch64_ldset4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: drivers/misc/eventlib/eventlib_flt.o: in function `sync_test_and_set_bit':
/home/output/ips/build/linux-5.10.120/nvidia/drivers/misc/eventlib/eventlib_flt.h:160: undefined reference to `__aarch64_ldset4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/osi_hal.o: in function `get_tx_ts':
/home/output/ips/build/linux-5.10.120/nvethernetrm/osi/core/osi_hal.c:1781: undefined reference to `__aarch64_ldadd4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: /home/output/ips/build/linux-5.10.120/nvethernetrm/osi/core/osi_hal.c:1829: undefined reference to `__aarch64_ldadd4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/osi_hal.o: in function `osi_lock_irq_enabled':
/home/output/ips/build/linux-5.10.120/nvethernetrm/include/../osi/common/common.h:127: undefined reference to `__aarch64_cas4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/osi_hal.o: in function `osi_unlock_irq_enabled':
/home/output/ips/build/linux-5.10.120/nvethernetrm/include/../osi/common/common.h:156: undefined reference to `__aarch64_cas4_acq_rel'
/home/output/ips/build/linux-5.10.120/nvethernetrm/osi/core/osi_hal.c:1783: undefined reference to `__aarch64_ldadd4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/macsec.o: in function `osi_lock_irq_enabled':
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/macsec.o: in function `osi_unlock_irq_enabled':
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/eqos_core.o: in function `eqos_pad_calibrate':
/home/output/ips/build/linux-5.10.120/nvethernetrm/osi/core/eqos_core.c:169: undefined reference to `__aarch64_cas4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: /home/output/ips/build/linux-5.10.120/nvethernetrm/osi/core/eqos_core.c:229: undefined reference to `__aarch64_cas4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/mgbe_core.o: in function `mgbe_handle_mac_intrs':
/home/output/ips/build/linux-5.10.120/nvethernetrm/osi/core/mgbe_core.c:2260: undefined reference to `__aarch64_ldadd4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: /home/output/ips/build/linux-5.10.120/nvethernetrm/osi/core/mgbe_core.c:2309: undefined reference to `__aarch64_ldadd4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: /home/output/ips/build/linux-5.10.120/nvethernetrm/osi/core/mgbe_core.c:2262: undefined reference to `__aarch64_ldadd4_acq_rel'
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/core_common.o: in function `osi_unlock_irq_enabled':
/home/output/ips/host/bin/aarch64-linux-ld: drivers/net/ethernet/nvidia/nvethernet/nvethernetrm/osi/core/core_common.o: in function `osi_lock_irq_enabled':
make[2]: *** [Makefile:1211: vmlinux] Error 1
make[1]: *** [package/pkg-generic.mk:293: /home/output/ips/build/linux-5.10.120/.stamp_built] Error 2
make: *** [Makefile:23: _all] Error 2
