Thank you for taking your time reading this post.
Here is my problem:
I ported a C++ project into CUDA.
I mimicked CUDA SDK, simpleTexture3D
and wrote kernel launch wrapper in cpp code.
I set up the breakpoint at kernel launch. It is hit.
I pressed step in. It ignores kernel function and skips to next line.
CUT_CHECK_ERROR(“Kernel execution failed”); code just stops the program. There must be a kernel launch error.
I tried the same step in simpleTexture3D. The breakpoint is hit and step-in brings me to the kernel function (although one more press gives me no source code.)
Here is how I implemented CUDA.
[codebox]
Callbacks.cpp
extern “C” void launchKernel(…);
void render(){
launchKernel(…);
kernel.cu
global void kernel(…) { … }
extern “C” void launchKernel(…){
kernell<<…>>(…);
[/codebox]
This seemed all I needed to launch kernel. I’m using CUDA Build Rule v3.0.14
and I’m greatly in need of help.
Thank you.
Okay… my previous blockSize was (32,32,1).
I changed that into (16,16,1), and there I got different output, or rather a message box saying
there is no source code available for the current location.
Does this mean my kernel is running?
Also, I’m passing in float* d_output
and in the kernel, I called d_output[i] = 10; //an arbitrary number.
I called cout << d_output[i] << endl; after the kernel launch wrapper and it prints out 0.
Does this mean the kernel hasn’t been called, since it’s all zero?
This time, the application doesn’t terminate with CUT_CHECK_ERROR(“Kernel execution failed”)
Does this mean anything?
You should do proper memory allocation and copying between host and device. You cannot cout << device memory.
Oh, that was just to see what’s in there, which I believe is not the elegant way of doing so.
It’s not a question of elegance, actually. If you dereference a device pointer on the host (or vice versa), you will either get random garbage or a segfault. They are completely independent memory spaces. You have to cudaMemcpy() between host and device pointers to move this kind of data back and forth.
