My orin module cannot boot normally. It will be stuck when it starts.I have attached the log.Please help me to check.
boot_stuck.log (109.9 KB)
Is this your first time using jetson? This is not an error.
The device is waiting for you to configure your user account so that it can move on.
btw, Now the kernel is stuck when I am adding a spi2 device node by following the attached file.Below is the log:Log:
[ 15.793121] ox03c10_a 2-0010: dual camera detect success
[ 15.798698] ox03c10_a 2-0010: Detected OX03C10 sensor
[ 15.804149] ox03c10_a 2-0011: probing v4l2 sensor.
[ 15.809286] ox03c10_a 2-0011: tegracam sensor driver:ox03c10_1_v2.0.6
[ 15.945367] ox03c10_a 2-0011: dual camera detect success
[ 15.950945] ox03c10_a 2-0011: Detected OX03C10 sensor
[ 15.956376] ox03c10_a 2-0012: probing v4l2 sensor.
[ 15.961515] ox03c10_a 2-0012: tegracam sensor driver:ox03c10_2_v2.0.6
[ 16.097359] ox03c10_a 2-0012: dual camera detect success
[ 16.102943] ox03c10_a 2-0012: Detected OX03C10 sensor
[ 16.108378] ox03c10_a 2-0013: probing v4l2 sensor.
[ 16.113495] ox03c10_a 2-0013: tegracam sensor driver:ox03c10_3_v2.0.6
[ 16.249361] ox03c10_a 2-0013: dual camera detect success
[ 16.254942] ox03c10_a 2-0013: Detected OX03C10 sensor
[ 16.260265] max96712_a 2-004d: max96712_probe: enter
[ 16.265452] debugfs: Directory ‘max96712_a’ with parent ‘/’ already present!
[ 16.272718] max96712_a 2-004d: max96712_probe: success
[ 16.289052] irq: IRQ308: trimming hierarchy from :pmc@c360000
[ 16.313904] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 16.328664] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 16.341487] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 16.349134] tegra194-pcie 14100000.pcie: tegra_pcie_dw_probe probe start ##################
[ 16.351017] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 16.357841] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 16.369361] tegra194-pcie 14100000.pcie: tegra_pcie_dw_probe ############## DW_PCIE_RC_TYPE
[ 16.371870] irq: IRQ311: trimming hierarchy from :interrupt-controller@f400000-1
[ 16.372156] mmc0: CQHCI version 5.10
[ 16.389556] tegra194-pcie 14100000.pcie: tegra_pcie_config_rp ##############################
[ 16.389589] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 311
[ 16.405142] tegra194-pcie 14100000.pcie: tegra_pcie_enable_phy ##############################
[ 16.414183] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 16.417120] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 16.421366] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 16.438124] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 16.446818] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 16.518947] mmc0: Command Queue Engine enabled
[ 16.523522] mmc0: periodic cache flush enabled
[ 16.528099] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 16.535111] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 16.539824] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[ 16.559279] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 16.561119] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 16.673760] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 16.782777] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 16.891791] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.000809] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.109819] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.218833] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.327854] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.429265] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.538278] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.647296] tegra194-pcie 14100000.pcie: Phy link never came up
[ 17.653455] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 17.660278] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 17.665921] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 17.675764] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 17.686609] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 17.694548] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 17.700894] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 17.710916] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.723584] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 17.728978] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 17.737940] pcieport 0001:00:00.0: Adding to iommu group 9
[ 17.743857] pcieport 0001:00:00.0: PME: Signaling with IRQ 51
[ 17.750163] pcieport 0001:00:00.0: AER: enabled with IRQ 51
[ 17.756024] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.764902] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.773864] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 17.779972] pci 0001:00:00.0: Removing from iommu group 9
[ 17.785537] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 17.791586] tegra194-pcie 14100000.pcie: tegra_pcie_dw_link_up ##############################
[ 17.801396] tegra194-pcie 14100000.pcie: tegra_pcie_dw_probe probe end ##################
[ 17.810676] tegra194-pcie 14160000.pcie: tegra_pcie_dw_probe probe start ##################
[ 17.819398] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 17.826048] tegra194-pcie 14160000.pcie: tegra_pcie_dw_probe ############## DW_PCIE_RC_TYPE
[ 17.835265] tegra194-pcie 14160000.pcie: tegra_pcie_config_rp ##############################
[ 17.844948] tegra194-pcie 14160000.pcie: tegra_pcie_enable_phy ##############################
[ 17.854119] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 17.861306] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 17.870005] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 17.878711] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 17.993263] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.102280] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.211294] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.320308] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.429324] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.538338] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.647354] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.756372] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.865387] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.974403] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.083417] tegra194-pcie 14160000.pcie: Phy link never came up
[ 19.089576] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 19.096398] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 19.102039] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 19.112151] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 19.122992] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 19.130922] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 19.137269] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 19.147082] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.159730] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 19.165130] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 19.174073] pcieport 0004:00:00.0: Adding to iommu group 10
[ 19.180051] pcieport 0004:00:00.0: PME: Signaling with IRQ 53
[ 19.186339] pcieport 0004:00:00.0: AER: enabled with IRQ 53
[ 19.192218] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.201096] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.210040] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 19.216127] pci 0004:00:00.0: Removing from iommu group 10
[ 19.221778] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 19.227839] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.237752] tegra194-pcie 14160000.pcie: tegra_pcie_dw_probe probe end ##################
[ 19.246781] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_probe probe start ##################
[ 19.255498] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 19.262166] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 19.267198] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 19.272137] vdd-dp: supplied by vdd-3v3-sys
[ 19.276589] vdd-3v3-sd: supplied by vdd-3v3-sys
Are you saying that this issue happened after you add this patch?
If you don’t add this patch, then it can boot up fine?
Yes, exactly.Below is the OK log:
[ 18.344974] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 18.351055] tegra194-pcie 14160000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.360972] tegra194-pcie 14160000.pcie: tegra_pcie_dw_probe probe end ##################
[ 18.370042] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_probe probe start ##################
[ 18.378772] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 18.385434] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 18.390470] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 18.395407] vdd-dp: supplied by vdd-3v3-sys
[ 18.399864] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 18.404851] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 18.410217] reg-fixed-voltage regulator-usbc_vcc5v0: nonexclusive access to GPIO for regulator-usbc_vcc5v0
[ 18.420435] irq: IRQ312: trimming hierarchy from :pmc@c360000
[ 18.439588] tegra194-isp5 14800000.isp: initialized
[ 18.454879] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 18.461343] (NULL device *): fops function table already registered
[ 18.468765] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 18.475617] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_probe probe start ##################
[ 18.475729] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 18.484343] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 18.496030] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_probe ############## DW_PCIE_RC_TYPE
[ 18.498415] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 311
[ 18.505139] tegra194-pcie 141a0000.pcie: tegra_pcie_config_rp ##############################
[ 18.625487] tegra194-pcie 141a0000.pcie: tegra_pcie_enable_phy ##############################
[ 18.634781] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 18.641971] tegra194-pcie 141a0000.pcie: IO 0x003a100000…0x003a1fffff → 0x003a100000
[ 18.650661] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000…0x2b2fffffff → 0x0040000000
[ 18.659351] tegra194-pcie 141a0000.pcie: MEM 0x2740000000…0x2b27ffffff → 0x2740000000
[ 18.776502] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.885518] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 18.994536] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.103551] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.212567] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.321587] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.430600] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.539620] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.567475] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 19.648634] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.757650] tegra194-pcie 141a0000.pcie: tegra_pcie_dw_link_up ##############################
[ 19.866658] tegra194-pcie 141a0000.pcie: Phy link never came up
Can you tell me how to compile and download firmware When I modify “tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi” and “tegra234-mb1-bct-gpio-p3701-0000.dtsi”?I think maybe there’s something wrong with my steps.
Btw, Can you tell me the difference between these two files.I don’t think there’s much difference between the changes in it.
These two files do not need any “compilation”. When flash script is doing flash work, it will pick up the file directly.
If you ever “compiled” it, then your step is wrong…
