As the topic,
I flash the JetPack5.1.1, L4T35.3.1 on the hardware Orin 32GB Module and AGX Orin DevKit Carrier Board.
There is no errror about flash process. But after I finish the flash process, the module reset and boot fail, and the console shows Kernel Panic.
Is there any idea about it?
My Hardware:
Orin 32GB Module(P3701-0004)
AGX Orin DevKit Carrier Board(P3737-0000)
My Software:
JetPack5.1.1, L4T35.3.1 without modification
My Flash command:
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
Here is the full flash log on host, and full console log on the module.
orin_devkit_jp5.1.1_flash.log (189.8 KB)
orin_devkit_jp5.1.1_console_kernel_panic.log (229.3 KB)
The error in console log is as below:
[ 11.595453] Run /init as init process
[ 11.611062] Root device found: mmcblk0p1
[ 11.619651] Found dev node: /dev/mmcblk0p1
[ 11.649202] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.659070] Rootfs mounted over mmcblk0p1
[ 11.679587] Switching from initrd to actual rootfs
[ 11.783987] systemd[1]: System time before build time, advancing clock.
[ 11.830176] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCO)
[ 11.855196] systemd[1]: Detected architecture arm64.
[ 11.905638] systemd[1]: No hostname configured.
[ 11.910952] systemd[1]: Set hostname to <localhost>.
[ 12.106831] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.114374] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 12.128120] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 12.138335] systemd[1]: Created slice system-modprobe.slice.
[ 12.145716] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.153330] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.164465] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.171999] systemd[1]: Reached target Slices.
[ 12.177999] systemd[1]: Reached target Swap.
[ 12.184033] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.192314] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.200734] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.209137] systemd[1]: Listening on Journal Audit Socket.
[ 12.216374] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.224097] systemd[1]: Listening on Journal Socket.
[ 12.230853] systemd[1]: Listening on udev Control Socket.
[ 12.238005] systemd[1]: Listening on udev Kernel Socket.
[ 12.245907] systemd[1]: Mounting Huge Pages File System...
[ 12.254004] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.263051] systemd[1]: Mounting Kernel Debug File System...
[ 12.271359] systemd[1]: Mounting Kernel Trace File System...
[ 12.279905] systemd[1]: Starting Journal Service...
[ 12.287410] systemd[1]: Starting Set the console keyboard layout...
[ 12.296470] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 12.307912] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 12.317574] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 12.326644] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 12.335648] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 12.344718] systemd[1]: Starting Load Kernel Module ramoops...
[ 12.353354] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 12.363109] systemd[1]: Started Nameserver information manager.
[ 12.371072] systemd[1]: Reached target Network (Pre).
[ 12.378928] systemd[1]: Starting Set console scheme...
[ 12.386484] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 12.396619] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 12.414385] systemd[1]: Starting Load Kernel Modules...
[ 12.422255] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.430204] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 12.430987] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 12.444884] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000000833000000,16777216
[ 12.445710] systemd[1]: Starting udev Coldplug all Devices...
[ 12.455272] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 12.471072] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[ 12.481535] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 12.481542] nvmap_page_pool_init: Total RAM pages: 7830522
[ 12.497054] nvmap_page_pool_init: nvmap page pool size: 978815 pages (3823 MB)
[ 12.497096] nvmap_background_zero_thread: PP zeroing thread starting.
[ 12.497183] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[ 12.500379] misc nvmap: created heap fsi base 0x0000000833000000 size (16384KiB)
[ 12.532045] systemd[1]: Started Journal Service.
[ 12.566860] systemd-journald[277]: Received client request to flush runtime journal.
[ 12.586490] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 12.586490]
[ 14.565230] random: crng init done
[ 14.569405] random: 7 urandom warning(s) missed due to ratelimiting
[ 14.940248] Internal error: SP/PC alignment exception: 8a000000 [#1] PREEMPT SMP
[ 14.948415] Modules linked in: ina3221 pwm_fan nvgpu nvmap ip_tables x_tables
[ 14.948429] CPU: 1 PID: 19 Comm: ksoftirqd/1 Not tainted 5.10.104-tegra #1
[ 14.948430] Hardware name: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 3.1-32827747 03/19/2023
[ 14.948432] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[ 14.948437] pc : 0x570e6cb99c9325
[ 14.948445] lr : rcu_core+0x274/0x980
[ 14.948446] sp : ffff8000101bbc90
[ 14.948447] x29: ffff8000101bbc90 x28: ffffb877a9607000
[ 14.948448] x27: ffff0b9bc02eba00 x26: ffff0b9bc02eba00
[ 14.948449] x25: ffff8000101bbd20 x24: ffff0ba2eeb45af0
[ 14.948451] x23: ffffb877a998ae40 x22: ffff0b9bc02eba00
[ 14.948452] x21: ffffb877a98f8998 x20: ffffb877a9607000
[ 14.948453] x19: ffff0ba2eeb45a80 x18: 0000000000000000
[ 14.948455] x17: 0000000000000000 x16: 0000000000000000
[ 14.948456] x15: 0000000000000000 x14: 0000000000000000
[ 14.948457] x13: 00000000fffee918 x12: ffffffffffffff51
[ 14.948458] x11: ffffb877a98f6000 x10: 0000000000000a80
[ 14.948460] x9 : ffff8000101bbd40 x8 : ffff0b9bc02eba00
[ 14.948461] x7 : 0000000000000020 x6 : ffff532b45529000
[ 14.948462] x5 : 0000000000000001 x4 : fffffe2e6f0e2ca0
[ 14.948464] x3 : 0000000080200004 x2 : ffff0b9bcb8b3800
[ 14.948465] x1 : ca570e6cb99c9325 x0 : ffff0b9bcb8b3800
[ 14.948467] Call trace:
[ 14.948468] 0x570e6cb99c9325
[ 14.948470] rcu_core_si+0x18/0x20
[ 14.948473] __do_softirq+0x140/0x3e8
[ 14.948478] run_ksoftirqd+0x50/0x60
[ 14.948481] smpboot_thread_fn+0x1c4/0x280
[ 14.948482] kthread+0x148/0x170
[ 14.948484] ret_from_fork+0x10/0x24
[ 14.948491] Code: bad PC value
[ 14.948499] ---[ end trace f27e1fcd77ee3fe3 ]---
[ 14.948501] Kernel panic - not syncing: SP/PC alignment exception: Fatal exception in interrupt
[ 14.948502] SMP: stopping secondary CPUs
[ 14.948510] Kernel Offset: 0x387797be0000 from 0xffff800010000000
[ 14.948511] PHYS_OFFSET: 0xfffff46540000000
[ 14.948512] CPU features: 0x0040006,4a80aa38
[ 14.948513] Memory Limit: none
[ 15.156947] ---[ end Kernel panic - not syncing: SP/PC alignment exception: Fatal exception in interrupt ]---
