Kit crash when writer uses bounding_box_2d_tight
Summary
When a Replicator writer is initialized with bounding_box_2d_tight=True, Kit crashes on the first orchestrator step. The same scene works fine if I only enable rgb. The log shows warnings about a version mismatch in omni::fabric::IStageReaderWriter and about a missing attribute on the DispatchSync node just before the crash.
Environment
  • Kit SDK: 110.1.1+production.305458.6312fa25.gl
  • omni.replicator.core: 1.13.4
  • omni.warp.core: pinned to 1.12.0
  • OS: Ubuntu 24.04.3
  • GPU: NVIDIA RTX 4500 Ada, driver 570.211.01, CUDA 12.8
  • Graphics API: Vulkan
App
Custom Kit app built from kit-app-template, Kit SDK 110.1.1.
Relevant pins from the .kit file:
“omni.warp.core” = “=1.12.0” # pinned (note: replicator.core+110.0.0 needs warp 1.12)
“omni.replicator.core” = “1.13.4” # resolved
“omni.replicator.nv” = “1.1.0” # resolved
“omni.kit.developer.bundle” = enabled
No other replicator/syntheticdata/fabric pins.
Steps to reproduce
Run this NVIDIA Replicator snippet from the Script Editor:
with rep.new_layer():
    camera_positions = [(-500, 200, -500), (500, 500, 500)]
    distance_light = rep.create.light(
rotation=(315, 0, 0), intensity=3000, light_type="distant"
    camera = rep.create.camera(focus_distance=200, f_stop=0.5)
    cube = rep.create.cube(semantics=[("class", "cube")], position=(0, 0, 0))
    render_product = rep.create.render_product(camera, (1024, 1024))
    writer = rep.WriterRegistry.get("BasicWriter")
    writer.initialize(
output_dir="_output_camera_posfromlist",
rgb=True,
    writer.attach([render_product])
with rep.trigger.on_frame(num_frames=10):
with camera:
            rep.modify.pose(
position=rep.distribution.choice(camera_positions),
look_at=(0, 0, 0),
  • With bounding_box_2d_tight=True: Kit crashes shortly after starting the pipeline.
  • With only rgb=True: runs to completion.
Log just before the crash
[omni.replicator.core.scripts.trigger]
    `trigger.on_frame` argument `num_frames` will be deprecated. Please use `max_execs`.
[rtx.hydra]
    Disabling DLSS Frame Generation for at least one view due to incompatible
    render outputs and OmniGraph postprocessing being active
[omni.syntheticdata.plugin]
    OgnSdPostRenderVarToHost: rendervar copy from texture directly to host buffer
    is counter-performant.
Warning: Possible version incompatibility. Attempting to load
         omni::fabric::IStageReaderWriter with version v0.16 against v0.14.
[omni.fabric.plugin]
    Warning: attribute inputs:simTimesToWrite not found for path
    /Render/PostProcess/SDGPipeline/DispatchSync
[carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.
repo launch exits with code -11 (SIGSEGV). Breakpad dump file is written under ~/.local/share/ov/data/Kit/<app>/...dmp.zip.
Crash metadata (from Breakpad)
  • lastCommand: CreateNodeCommand(graph=?, node_path=/Orchestrator/OgnReadFabricTime, node_type=omni.replicator.core.ReadFabricTime, create_usd=True)
  • lastCommands (most recent first, abbreviated):
    • CreateNodeCommand /Orchestrator/OgnReadFabricTime (omni.replicator.core.ReadFabricTime)
    • CreateGraphAsNodeCommand /Orchestrator (push evaluator)
    • CreateNodeCommand /Replicator/SDGPipeline/OgnCount
    • CreateNodeCommand /Replicator/SDGPipeline/OgnSetPrimPose
    • CreateNodeCommand /Replicator/SDGPipeline/OgnSampleUniform
    • CreateNodeCommand /Replicator/SDGPipeline/OgnOnFrame
    • CreateNodeCommand /WriterOrchestrator/ReadFabricTime
    • CreateNodeCommand /WriterOrchestrator/OgnScheduleWriter
    • CreateNodeCommand /WriterOrchestrator/OgnOnFrame
Crash backtrace (top frames, low-confidence symbols)
000  libc.so.6 __sigaction
001  libomni.fabric.plugin.so
002  libomni.replicator.core.plugin.so
003  libomni.replicator.core.plugin.so
004  libomni.graph.action_core.plugin.so
019  libomni.graph.core.plugin.so
020  _omni_graph_core.cpython-312-x86_64-linux-gnu.so
025  libpython3.12.so.1.0  _PyEval_EvalFrameDefault
What I tried
  • Cleared ~/.cache/ov and the per-app Kit data folder, then rebuilt with repo build -u. Same crash.
  • Using only rgb=True (no bounding boxes): works.
  • Different writer parameters / different example scripts: same crash whenever bounding_box_2d_tight=True is enabled.
