Kubuntu 22.04 don't use GTX 1650 Ti
Hi, I’m new with Kubuntu 22.04 and installed it on my machine but it use UHD graphics instead of GTX 1650 Ti, I tried setting it with nvidia-setting but it doesn’t work.
Here’s the result of “lshw -C display”
*-display UNCLAIMED
description: VGA compatible controller
product: TU117M [GeForce GTX 1650 Ti Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list
configuration: latency=0
resources: memory:c4000000-c4ffffff memory:b0000000-bfffffff memory:c0000000-c1ffffff ioport:4000(size=128) memory:c3000000-c307ffff
*-display
product: CometLake-H GT2 [UHD Graphics]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 05
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 resolution=1920,1080
resources: irq:138 memory:c2000000-c2ffffff memory:a0000000-afffffff ioport:5000(size=64) memory:c0000-dffff
also, here’s the bug report
nvidia-bug-report.log.gz (120.1 KB)
Can someone help me? Thank you so much
Please try installing kernel headers
sudo apt install linux-headers-$(uname -r)
I had the same problem with MX 21 Linux, using KDE. Nitro 5, with GTX 1650TI, AMD-GPU Renoir.
I followed the guidelines for installing the owner NVIDIA driver. Installed.
Now the notebook, does not care. Only the HDMI port (4K monitor).
How to activate notebook, without taking the updated driver (nvidia) that is working great?
