I can’t install the latest GTX 1650ti (notebook) driver(version 450.66) manually on a Ubuntu 16.04 system. Error report is in the Attach Documents.
software environmental:
ubuntu 16.04 with linux kernel 5.4.0, gcc version is 5.4.0.
hardware:
sudo lshw -C display
*-display UNCLAIMED description: VGA compatible controller product: NVIDIA Corporation vendor: NVIDIA Corporation physical id: 0 bus info: pci@0000:01:00.0 version: a1 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress vga_controller cap_list configuration: latency=0 resources: memory:fb000000-fbffffff memory:b0000000-bfffffff memory:c0000000-c1ffffff ioport:f000(size=128) memory:fc000000-fc07ffff *-display UNCLAIMED description: VGA compatible controller product: Advanced Micro Devices, Inc. [AMD/ATI] vendor: Advanced Micro Devices, Inc. [AMD/ATI] physical id: 0 bus info: pci@0000:06:00.0 version: c7 width: 64 bits clock: 33MHz capabilities: pm pciexpress msi msix vga_controller bus_master cap_list configuration: latency=0 resources: memory:d0000000-d
nvidia-seetings
ERROR: Unable to load info from any available system
I have two questions:
Could the latest nvidia driver(version 450.66) for GTX 1650ti on linux be support by ubuntu 16.04 with linux kernel 5.4.0?
If the first question’s answer is yes, then what should I do to install this diver correctly?
Thanks for help.nvidia-installer.log (1.8 KB)
