Hi, i’ve been working on a server project recently to learn (and teach myself) how to work with Linux and networking. I’ve bought a GTX 1650 for my transcoding on Plex, but installing the drivers for my server wont work propperly. I’ve tried many forum solutions, but none have seemed to work. I will try to provide as much information as possible, please ask for more if needed.
I installed the driver using
sudo apt install nvidia-driver-535
Purged all the files multiple times. Updated and upgraded all my packages. Autoremoved unused packages.
nvidia-bug-report.sh output:
nvidia-bug-report.log (382.6 KB)
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
nvidia-settings
ERROR: NVIDIA driver is not loaded
(nvidia-settings:4037): GLib-GObject-CRITICAL **: 18:08:20.587: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:4037): CRITICAL **: 18:08:20.589: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
uname -r
6.9.2-060902-generic
dkms status
nvidia/535.171.04: added
lspci -v | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation TU117 [GeForce GTX 1650] (rev a1) (prog-if 00 [VGA controller])
ubuntu-drivers devices
sudo == /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001F82sv00001458sd00004026bc03sc00i00
vendor : NVIDIA Corporation
model : TU117 [GeForce GTX 1650]
driver : nvidia-driver-450-server - distro non-free
driver : nvidia-driver-545 - distro non-free
driver : nvidia-driver-535-server-open - distro non-free
driver : nvidia-driver-535-open - distro non-free
driver : nvidia-driver-535-server - distro non-free
driver : nvidia-driver-545-open - distro non-free
driver : nvidia-driver-535 - distro non-free recommended
driver : nvidia-driver-470 - distro non-free
driver : nvidia-driver-418-server - distro non-free
driver : nvidia-driver-470-server - distro non-free
driver : xserver-xorg-video-nouveau - distro free builtin
dpkg -l |grep nvidia
ii libnvidia-cfg1-535:amd64 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-535 535.171.04-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-535:amd64 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-decode-535:amd64 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-535:amd64 535.171.04-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-535:amd64 535.171.04-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-535:amd64 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-535:amd64 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-535 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-535 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-535 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA driver metapackage
ii nvidia-firmware-535-535.171.04 535.171.04-0ubuntu0.22.04.1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-535 535.171.04-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-535 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-535 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-535 535.171.04-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
If anyone has ANY solutions for me, please let me know. I’ve been on this for the past 2 days. Thank you all so much in advance!
