L4T 34.1.1 Bootlin toolchain command line option error
I can try. I thought jetpack 5_0_1 requires 20.04 and above
I solved this issue (still with Ubuntu 22.04)
Apparently this error occurred since it couldn’t find the cross compiler path (or something like that).
For building the custom kernel I exported:
export CROSS_COMPILE_AARCH64_PATH=$WORKSPACE_PATH/ToolChain
For some reason that wasn’t enough for the:
sudo make ARCH=arm64 O=$KERNEL_OUT_PATH -j2
command (the command line option error occurred)
So I entered the following command instead:
sudo make CROSS_COMPILE=$WORKSPACE_PATH/ToolChain/bin/aarch64-buildroot-linux-gnu- ARCH=arm64 O=$KERNEL_OUT_PATH -j2
and that worked. I don’t know why the first export wasn’t enough even tough it worked for the kernel build using the nvbuild script
