L4T Base docker image for Jetpack 6.2 (r36.4.3)
When will the L4T base docker image for r36.4.3 be available?
Currently, I can only find the images up to r36.2.0 in the catalog.
Thank you.
The docker is deprecated. Please use L4T Jetpack:
NVIDIA L4T JetPack | NVIDIA NGC
r36.4.0 can be run on r36.4.3 BSP.
Thank you @DaneLLL for the reply.
L4T Jetpack image is ~5GB, while the L4T base was just ~250MB.
We don’t need all of the Jetpack components, it would be great if we can use the L4T Base image.
Is the source Dockerfile available for L4T Jetpack? So that I can tune it for my use case.
Please use l4t-cuda instead.
You can find below topic for more details:
Thank you @AastaLLL
runtime image is around 1.21GB. It is much better than 5GB.
Is the sources available for any of L4T images?
I use only the accelerated gstreamer in that container and making the image smaller in size is really important for us. Any suggestion from you on shrinking the image size is much appreciated.
No, as we support Linux distro from JetPack 6, there is no L4T image anymore.
But the standard Ubuntu image should work correctly and try to use l4t-cuda if GPU is required.
