No l4t-base:r36.3.0 docker image
This is a follow up to this question about there being no l4t-base:r36.3.0 for Jetpack 6.0.
I have an Orin AGX (although I also have an Orin NX 16GB I will use) with Jetpack 5.1.2 on it and am trying to build a container based on JP 6.0. Per the above forum post since there is no l4t-base:r36.3.0 I tried nvcr.io/nvidia/l4t-cuda:12.2.12-runtime as that seemed to be the equivalent of l4t-base with the cuda version matched up to jetpack 6.0 (although I guess there doesn’t seem to be a way to tell if it actually is jetpack 6.0.)
When trying to do anything with that container, however, I get this error:
$ docker run -it --rm nvcr.io/nvidia/l4t-cuda:12.2.12-runtime bash
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: nvidia-container-runtime did not terminate successfully: exit status 1: time="2024-10-14T14:52:35-04:00" level=error msg="failed to create NVIDIA Container Runtime: failed to construct OCI spec modifier: requirements not met: unsatisfied condition: cuda>=12.2 (cuda=11.4)"
: unknown.
For the particular container I need, I don’t actually need cuda, I am just looking for an equivalent to l4t-base. Strangely, the image nvcr.io/nvidia/l4t-jetpack:r36.3.0 appears to work fine, but it’s a bit bigger than I would like for this application.
There’s no reason in particular I’m trying to run JP 6.0 from Jetpack 5.1.2 other than I’m trying to get ahead on moving to jetpack 6.0 but not ready to actually update my board. Is there another l4t-base docker image alternative for jetpack 6.0?
As you already know, we recommend users try l4t-cuda since we support Linux distro now.
But we can check this issue internally for more info.
You can use nvcr.io/nvidia/base/ubuntu:22.04_20240212 as alternative.
The following debs are pre-installed in the l4t-base but not the nvcr.io/nvidia/base/ubuntu:22.04_20240212.
bc
bzip2
can-utils
ca-certificates
freeglut3-dev
gnupg2
gstreamer1.0-alsa
gstreamer1.0-libav
gstreamer1.0-plugins-bad
gstreamer1.0-plugins-base
gstreamer1.0-plugins-good
gstreamer1.0-plugins-ugly
gstreamer1.0-tools
i2c-tools
iw
kbd
kmod
language-pack-en-base
libapt-pkg-dev
libcanberra-gtk3-module
libgles2
libglu1-mesa-dev
libglvnd-dev
libgtk-3-0
libpython2.7
libudev1
libvulkan1
libzmq5
mtd-utils
parted
pciutils
python
python-pexpect
python3-distutils
python3-numpy
sox
udev
vulkan-utils
wget
wireless-tools wpasupplica
You can install the debs if needed.
