I am trying to use docker image nvidia/cuda:11.8.0-devel-ubuntu20.04.
And yes, I installed cuda 11.8 with the link above on the Orin Nano, since I thought the error means the host required to have 11.8 or above to support running cuda 11.8 in container.
Do you encounter any errors when using the CUDA 11.8 outside the container?
You will need to export the compat folder to solve the compatibility issue.
