When trying starting docker container with CUDA 11.8 the following error is shown:
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: nvidia-container-runot terminate successfully: exit status 1: time="2023-11-01T18:16:58-03:00" level=error msg="failed to create NVIDIA Container Runtime: failed to cCI spec modifier: requirements not met: unsatisfied condition: cuda>=11.8 (cuda=11.4)"
: unknown.
CUDA 11.8 is installed in my system (using https://developer.nvidia.com/blog/simplifying-cuda-upgrades-for-nvidia-jetson-users/ instructions)
LD_LIBRARY_PATH is set according to tutorial.
Full log output:
lxuser@agxdev:~$ echo $LD_LIBRARY_PATH
/usr/local/cuda-11.8/compat
lxuser@agxdev:~$
lxuser@agxdev:~$
lxuser@agxdev:~$ /usr/local/cuda/bin/nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:43:33_PDT_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
lxuser@agxdev:~$
lxuser@agxdev:~$
lxuser@agxdev:~$ cd cuda-samples/Samples/1_Utilities/deviceQuery
lxuser@agxdev:~/cuda-samples/Samples/1_Utilities/deviceQuery$
lxuser@agxdev:~/cuda-samples/Samples/1_Utilities/deviceQuery$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Orin"
CUDA Driver Version / Runtime Version 11.8 / 11.8
CUDA Capability Major/Minor version number: 8.7
Total amount of global memory: 62797 MBytes (65847091200 bytes)
(016) Multiprocessors, (128) CUDA Cores/MP: 2048 CUDA Cores
GPU Max Clock rate: 1300 MHz (1.30 GHz)
Memory Clock rate: 1300 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 167936 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.8, CUDA Runtime Version = 11.8, NumDevs = 1
Result = PASS
lxuser@agxdev:~/cuda-samples/Samples/1_Utilities/deviceQuery$ cd
lxuser@agxdev:~$
lxuser@agxdev:~$ docker run -it --rm --runtime nvidia nvidia/cuda:11.8.0-devel-ubuntu22.04
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: nvidia-container-runtime did not terminate successfully: exit status 1: time="2023-11-01T18:34:14-03:00" level=error msg="failed to create NVIDIA Container Runtime: failed to construct OCI spec modifier: requirements not met: unsatisfied condition: cuda>=11.8 (cuda=11.4)"
: unknown.
lxuser@agxdev:~$ ls $LD_LIBRARY_PATH
libcuda.so libcuda.so.1 libcuda.so.1.1 libnvidia-nvvm.so libnvidia-nvvm.so.4 libnvidia-ptxjitcompiler.so libnvidia-ptxjitcompiler.so.1
lxuser@agxdev:~$
I have also tried to add the LD_LIBRARY_PATH settings in docker systemd unit environment but no luck. Any Hints?
Tegra release/JP version:
# R35 (release), REVISION:
2.1
, GCID:
32413640
, BOARD: t186ref, EABI: aarch64, DATE: Tue Jan
24
23
38
33
UTC
2023
Package: nvidia-jetpack
Version:
5.1
-b147
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size:
194
Depends: nvidia-jetpack-runtime (=
5.1
-b147), nvidia-jetpack-dev (=
5.1
-b147)
