I could not install Cuda 11.8
My project uses Cuda 11.8, so I tried to install it. According to the Nvidia person, the link was here.
But I could not install it, and saw the following.
The following packages have unmet dependencies:
 cuda : Depends: cuda-11-8 (>= 11.8.0) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I wonder if I can install 11.8. Could you advise me?
Secondly, what is the supported Cuda versions for the Orin?
Best regards,
Which JetPack version do you use?
For JetPack 5, the OS is based on Ubuntu 20.04 so the available CUDA version is 11.4-12.2.
For JetPack 6, the OS is based on Ubuntu 22.04 so the available CUDA version is 12.2 and newer.
Hello AastaLLL,
Is there a way to check the JetPack version?
I just flashed the Orin board as per Set Up DRIVE OS Linux with NVIDIA GPU Cloud (NGC) | NVIDIA Docs
I could check the following.
seunghyun@tegra-ubuntu:~$ dpkg-query -l | grep "nvidia"
ii  libnvidia-container-tools            1.10.0-1                                arm64        NVIDIA container runtime library (command-line tools)
ii  libnvidia-container0:arm64           0.11.0+jetpack                          arm64        NVIDIA container runtime library
ii  libnvidia-container1:arm64           1.10.0-1                                arm64        NVIDIA container runtime library
ii  nvidia-container-toolkit             1.10.0-1                                arm64        NVIDIA container runtime hook
ii  nvidia-docker2                       2.11.0-1                                all          nvidia-docker CLI wrapper
Thank you for your help.
Best regards,
Seunghyun
Hi
The link you use is for the DRIVE system.
Do you use the DRIVE system?
Hi AastaLLL
Yes, I am using Drive OS 6.0.8.
Best regards,
Please help to open a new topic at DRIVE AGX Orin forum: Latest DRIVE AGX Orin/DRIVE AGX Orin General topics - NVIDIA Developer Forums
