NVIDIA docker container l4t-base:r36.3.0 not released
I noticed that the l4t-base container does not have a version r36.3.0 when the container l4t-jetpack does have it. (And the l4t-jetpack is based on the l4t-base container with the same version: Blame · Dockerfile.jetpack · master · nvidia / container-images / l4t-jetpack · GitLab)
Could you please fix this and make the r36.3.0 tag available ?
Thanks !
l4t-base: NVIDIA L4T Base | NVIDIA NGC
l4t-jetpack: NVIDIA L4T JetPack | NVIDIA NGC
Do you use Jetson Nano?
Please note that r36.3.0 cannot work on Jetson Nano.
Thanks for the information.
We are using Jetson NX 8GB. This should work with r36.3.0
Thanks for the info. Moving your topic to the Orin NX board.
From JetPack 6, we started to support Linux Distros so there won’t be an L4T container anymore.
Instead, you can use l4t-cuda.
