Missing Docker Images for JetPack 6.2/L4T 36.4.3 on NGC
I’m using NGC L4T JetPack Docker images (nvcr.io/nvidia/l4t-jetpack ) in our CI builds and am planning to upgrade to JetPack 6.2. However, I’ve noticed that there aren’t any official container images available on NVIDIA NGC for L4T version 36.4.3.
I attempted building the images from source using the container-images/l4t-jetpack repository, which does not build because l4t-base for this version is also missing. I tried to build that from source, but it doesn’t seem to have been updated recently.
Could someone please advise if there’s an official release plan for releasing container images for JetPack 6.2? Alternatively, is there an updated repository or recommended workaround to obtain these images?
Thanks in advance!
As JetPack 6.2 is updated from the JetPack 6.1, you can use the r36.4.0 image instead.
