flashing a nvme SSD on Xavier AGX floods my memory(host).
I Run the following command, with edited .xml to have the right sector size and size.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1 -c ./tools/kernel_flash/flash_l4t_nvme.xml -S 400GiB --showlogs --erase-all jetson-agx-xavier-devkit nvme0n1p1
And I get stuck here until oom and it crashes shortly after
[ 0.0368 ] Signed file: /home/felix/flash_jetson_stuff/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x45651 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/felix/flash_jetson_stuff/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Making system.img...
