i am trying to get a gstreamer chain up and running on the TX1 to get camera data as OpenCv::Mat. I started with a simple pipeline to capture the data from the camera and to display it on the display.
gst-launch-1.0 -e -v nvcamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvvidconv ! xvimagesink
Everything fine so far, no measurable latency.
Now when i exchange the xvimagesink with an appsink module to get a hand on the data, a delay of nearly 2 seconds is getting introduced.
It is not just a simple exchange, i build up the pipeline in source, translated as:
nvcamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvvidconv ! 'video/x-raw, format=(string)I420' ! videoconvert ! 'video/x-raw, format=(string)BGR' ! appsink
and pull data cyclically via
bool VideoCaptureGst::getFrame
cv::Mat& img,
int camId
bool gotFrame = false;
// pull_sample will block until sample is ready. In our case "sample" is an encoded picture.
GstSample* sample;
sample = gst_app_sink_pull_sample(GST_APP_SINK(gstCamMaster.appsink));
if(sample == NULL)
fprintf(stderr, "gst_app_sink_pull_sample returned null\n");
} else {
GstCaps *caps = gst_sample_get_caps(sample);
GstStructure* s = gst_caps_get_structure (caps, 0);
gint width, height;
(void)gst_structure_get_int (s, "width", &width);
(void)gst_structure_get_int (s, "height", &height);
GstBuffer* buffer = gst_sample_get_buffer (sample);
GstMapInfo map;
gst_buffer_map (buffer, &map, GST_MAP_READ);
// We do a deep copy of the data to pass it back to the caller
cv::Mat imgbuf = cv::Mat(cv::Size(width, height), CV_8UC3, (char*)map.data, cv::Mat::AUTO_STEP);
imgbuf.copyTo(img);
gst_buffer_unmap (buffer, &map);
gst_sample_unref (sample);
gotFrame = true;
return gotFrame;
I already played arround with settings for the appsink which has no effect on the latency.
gst_app_sink_set_max_buffers(GST_APP_SINK(gstCamMaster.appsink), 1);
gst_app_sink_set_drop(GST_APP_SINK(gstCamMaster.appsink), TRUE);
g_object_set (G_OBJECT(gstCamMaster.appsink), "async", FALSE, "sync", FALSE, NULL);
Does anyone has an idea or can explain what is going on?
