Latest win 11 drivers for NVIDIA GPu are bad on windows 11.
I’m on 11 PRO latest build, and latest NVIDIA Drivers for 2080 SUPER cause GPU usage to spike from 50-99% in IDLE. Downgrading gpu 4-5 months fixes it.
Open Issues:
Guess what, I have uninstalled every bit of NVIDIA…and using win11 default Drivers!
And I have ZERO problems, everything is fast!
Get rit of all Nvidia drivers! That’s the FIX!
If you downgrade to a older NVIDIA driver it works. 26.21.14.4587
Date : 2020 - 04-03
Hi Ryan,
I did, but still NVIDIA drivers are slowing down, and are unreliable.
So, I go without the drivers…
Which version of driver are you on and date? You can check in taskmanager.
I have checked them all out!
Some are better, some are worse, but none of them are reliable…
These Drivers I have tried
You need to go back further than that, mine are 6 months old, and good.
around Date : 2020 - 04-03 should be good.
