I’m moving a NVS 810 card to a newer PC running windows 11. I have what I think is the latest driver (474.64, dated Oct 2023) installed, but Windows only detects a single GPU, and as a result I can only see 4 of the 7 monitors. Is there a trick to get the driver (or Win 11) to see both GPUs so I can drive all 7 monitors?
Hi there @jhveeneman, welcome to the NVIDIA developer forums.
Unfortunately this will not work on Win 11. The newer drivers needed to fully support Windows 11 and the new WDDM are not compatible with the old GPU Hardware.
I am sorry!
Maybe you can consider upgrading with two separate, a bit more modern GPUs instead?
Thanks for the response. At least now I can stop chasing my tail and get on to Plan B.
Cheers!
